Old 07-07-2016, 05:00 PM   #1
Bushhy
Drives: None
CLUTCH NOISES WONT LEAVE ME ALONE :(
So, im starting to think I am cursed. My clutch is making some noises, and im about to light my car on fire for insurance money(only kidding).
First noise. When coasting downhill, my clutch makes this noise:
[ame="https://www.youtube.com/watch?v=TvHOWQHfJG4"]Clutch noise? - YouTube[/ame]
I have no idea what it is. And im about to lose it
Next noise. When sitting at idle, in neutral, and the clutch in, I can hear a faint noise that sounds like something rotating. When I push the clutch in, the noise goes away. It is very faint, so you can only hear it with the A/C off, and the radio off.
Sounds kinda like this video :
I don't believe its the transmission, because it sounds further up?
Any help that I can get would be amazing. Im trying to figure it out, but am lost Also, if its something that needs to be fixed, would it be covered under the Powertrain warranty?
Bushhy is offline   Reply With Quote
Old 07-07-2016, 05:22 PM   #2
How many miles on your car..??
Any power modifications..??
I'd guess it's the notorious throw out (release bearing).
If so, some have gotten it replaced under warranty ..... some not.
If that's the problem, the good news is that its not an expensive part; the bad news is that you have to take the transmission out to replace it.
Old 07-07-2016, 05:25 PM   #3
Bushhy
Drives: None
26000 miles. No mods other than the spring delete and clutch adjustment.
I thought throwout bearings only make noise when the clutch is pushed in? The noises happen when its not pushed in
Old 07-07-2016, 05:33 PM   #4
Since the TOB on these cars is an "active" type, as long as the engine is running, the TOB is turning.
True, that it is "working" only when the clutch pedal is depressed, however it can still make a racket when it is not working.
Where is @Ultramaroon when we need him ....... he's got a good ear for these powertrain noises .....
Old 07-07-2016, 05:34 PM   #5
Bushhy
Drives: None
Its starting to annoy me. I have had the car for less than 700 miles
Old 07-07-2016, 05:56 PM   #6
Is the car still under warranty ..... ??
If so, you may take it into the dealer for an evaluation.
Meanwhile, stay tuned for other keyboard mechanics to render an opinion.....
Old 07-07-2016, 05:59 PM   #7
Bushhy
Drives: None
Its out of basic and only have powertrain now :/
Old 07-07-2016, 09:15 PM   #8
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Take it in anyways. Make a fuss. Sometimes they might help you out. Just don't be rude to them.
Old 07-07-2016, 10:34 PM   #9
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
I don't mean to hijack this thread, but I noticed a similar issue today.
When I press the clutch in, there is a strange rotating/ grinding noise. Same when I'm braking with my engine but at lower RPMs (<3,000). Again, it's very subtle, and only really noticeable when music/ A/C is off. I do have power mods, so I'm curious if it's my clutch slipping? Sorry for the noobness, I normally do plenty of research.
MS, CSCS, TSAC-F, CPT
Old 07-07-2016, 10:41 PM   #10
Bushhy
Drives: None
My guess is you have a bad throwout bearing, and your flywheel is rattling.
The throwout bearing should make most of the noise with the clutch pushed in
Old 07-07-2016, 11:03 PM   #11
OP, it's fine. When engine braking at low RPM, feedback from the engine rattles the disengaged gears.
Same for the sound you hear when it's in neutral. Google "neutral rollover" and you'll feel much better. Welcome to the forum and enjoy your cool car.
edit: Sorry, @humfrz. My brother and I took the sports cars and ladies out to Point Reyes to see the lighthouse. Fun drive!
Old 07-07-2016, 11:13 PM   #12
weederr33
weederr33's Avatar
Well it just started happening and just in time for the 50,000 mile mark lol. I'll be upgrading my clutch hopefully by the end of the year.
Old 07-07-2016, 11:17 PM   #13
Yes, likely TOB in your case. Why "upgrade" your clutch. Does it slip now? Be rolling in top gear, disengage the clutch, add a little throttle to rev the engine and dump the clutch. Does it take a while for the engine speed to drop or does the clutch grab right away?
I've driven with some sketchy clutches. It's pretty easy to tell when they aren't quite up to the task.
Old 07-07-2016, 11:19 PM   #14
weederr33
weederr33's Avatar
No, it doesnt. Just an added precaution honestly.
Help!! Car Wont Start After Clutch Swap (25$ reward for solution!!) bren5279 Issues | Warranty | Recalls / TSB 44 07-03-2017 08:36 AM
Cruise control wont set after clutch install? ($$ reward for solution!) bren5279 Issues | Warranty | Recalls / TSB 18 12-05-2014 10:21 AM
Is there a clutch delay valve on BRZs? Chirping noises... torqueno Engine, Exhaust, Transmission 7 10-10-2014 12:48 PM
various noises abutterman Issues | Warranty | Recalls / TSB 0 10-23-2013 12:26 AM
I'll Just Leave This Here. Asterisked Accolade Off-Topic Lounge [WARNING: NO POLITICS] 11 06-11-2012 08:59 PM
