Old 07-05-2016, 05:44 PM   #1
adrixe
adrixe's Avatar
Drives: 2014 Subaru BRZ
Adding sub and amp on my brz
So I bought a jl audio stealth sub and 4 channel amp for my hummer h3. Didnt replace my stock woofer on it. Thinking of putting the stealth box to my brz.
What are the things I need to get this done? Planning on doing it by myself.
Does the stock hu have preouts for the subs?
Sent from my SM-N900W8 using Tapatalk
adrixe is offline   Reply With Quote
Old 07-07-2016, 10:24 PM   #2
greencounty
greencounty's Avatar
The stock headunit doesn't have preouts. You'll have to either use a line-out converter and a splice harness or maybe tap into the OEM amp.
Garage:
2013 BRZ Limited 6MT - Galaxy Blue
1994 Ford Probe GT 5MT - Red(some would argue pink)
1969 Mustang Fastback 4MT - Royal Maroon
greencounty is offline   Reply With Quote
Old 07-07-2016, 11:04 PM   #3
greencounty
I believe this is the type of splice harness that you're looking for:
http://www.autoharnesshouse.com/82191_info.html
Garage:
Old 07-07-2016, 11:09 PM   #4
adrixe
adrixe's Avatar
Thanks for that.
Anybody used it and have some instructions to do it?
Old 07-07-2016, 11:59 PM   #5
mithrandiir42
I also just installed a stealthbox sub in my BRZ. Though I replaced the headunit at the same time so it was a little different getting the vehicle side of the harness connected up to the harness for the headunit.
I did however build something very similar to this splice harness for my wife's Outback earlier this week. I bought the male and female Metra connectors and soldered them together to make a splice harness like that. Then spliced the the line-out converter into that. Worked great. Basically it was a matter of identifying which wires were what and splicing into them to connect to the line out converter. It looks like there are some photos identifying those on the product page. In my case, it was actually printed right on the wires themselves. If I recall correctly, the wires of interest were:
RIGHT FRONT+
RIGHT FRONT-
LEFT FRONT+
LEFT FRONT-
GROUND
12V
12V SWITCHED IGNITION
But back to the topic of audio upgrades in the BRZ. Does anyone know if there a similar splice harness for the rear amplifier that powers the door speakers or what connector & pinout is used for it?
mithrandiir42 is offline   Reply With Quote
Old 07-08-2016, 02:28 AM   #6
gramicci101
Off Topic
It's pretty easy to make one with the standard Metra Toyota harnesses. See the below thread.
http://www.ft86club.com/forums/showthread.php?t=107369
Old 07-08-2016, 08:56 PM   #7
mithrandiir42
Thanks, that's exactly what I was looking for.
Adding sensor to ECU Sporran Electronics | Audio | NAV | Infotainment 3 04-14-2015 06:55 AM
Adding TRD emblems to my frs? Jake_86 Cosmetic Modification (Interior/Exterior/Lighting) 19 03-03-2015 05:26 PM
adding a video twag4 Site Announcements / Questions / Issues 4 02-21-2014 01:28 PM
Adding 30 hp!!! cooldandani Engine, Exhaust, Transmission 62 11-17-2013 08:06 AM
Adding Coolant JLMtm Scion FR-S / Toyota 86 GT86 General Forum 5 05-11-2013 07:03 AM
