Old 04-12-2015, 12:59 PM   #1
Sporran
Drives: Metallic Grey 86
Adding sensor to ECU
I know that an aftermarket oil pressure sensor can be installed with a standalone oil pressure gauge, but is it possible to add an oil pressure sensor and wire it directly into the ECU so that oil pressure could then be available through the OBDII port using an app like Torque?
If so, how would one go about it?
Sporran is offline   Reply With Quote
The Following User Says Thank You to Sporran For This Useful Post:
Longuy (10-10-2021)
Old 04-13-2015, 06:37 PM   #2
robot
There are now 2 carseats!
Drives: 2013 DGM BRZ
No. The long and the short of it is that the ECU doesn't have an input or programming to "care" about oil pressure.
However, one could pressure the folks that write torque or other obdII apps to write software that used a wirelessly connected 0-5v logic sensor connected to microcontroller. (So, like a bluetooth arduino with a oil pressure sender connected to it.) It actually wouldn't be to hard for them to develop.
robot is offline   Reply With Quote
Old 04-13-2015, 08:12 PM   #3
zkv476
zkv476's Avatar
Drives: 2014 SWP BRZ, MT
Technically it could be done, though it's complicated. The ECU has a two inputs I know of that are commonly replaced with other devices, a CPC pressure sensor input commonly used for flexfuel sensors and the rear O2 sensor for widebands. There may be a way to get torque to read a specific memory address to pull the data from the ECU where that data is, but I don't know anything about it.
The shorter answer is nobody's done it or bothered to attempt it.
The answer is racecar. Always.
zkv476 is offline   Reply With Quote
Old 04-14-2015, 06:55 AM   #4
Sporran
Thanks for the replies. I thought a standalone gauge might be the only practical method of getting an oil pressure readout but wanted to see if wiring it into the ECU was a possibility - guess not.
is the front o2 sensor a wideband sensor? mad_sb Engine, Exhaust, Transmission 19 12-13-2015 02:20 PM
Greddy informeter, boost sensor, boost sensor harness, info touch sensor apaptor Supra2k Audio/Visual, Electronics, Infotainment, NAV 1 02-26-2014 08:11 PM
Adding 30 hp!!! cooldandani Engine, Exhaust, Transmission 62 11-17-2013 08:06 AM
Stock FA20 Crankshaft Angle Sensor - Anyone know what type of sensor and output? Acree Engine, Exhaust, Transmission 2 08-26-2013 06:39 PM
