Old 06-29-2016, 07:59 PM   #1
trigun286
trigun286's Avatar
Drives: '16 WRB Limited
Light flywheel?
Hey guys, I'm new to this forum and the car as well as manual so the whole nine yards. As I'm driving around town just cruising, I feel like I'm shifting too slowly as the rpms blip up every shift. This forces me to quickshift which I don't mind but just curious to know if it's just the cars flywheel or me just being silly.
Sent from my HTC One_M8 using Tapatalk
trigun286 is offline   Reply With Quote
Old 06-29-2016, 08:12 PM   #2
BassKeys88
BassKeys88's Avatar
Drives: 13' FRS
I've found that my car shifts smoothly around 5000 rpms and is a completely different animal above that
BassKeys88 is offline   Reply With Quote
Old 06-29-2016, 08:40 PM   #3
trigun286
trigun286's Avatar
I'm currently trying to keep it below 4k, which is super hard by the way because excitement, since it's the break in period.
Old 06-29-2016, 09:06 PM   #4
ryoma
ryoma's Avatar
I experience the opposite. 1st to 2nd I have to wait a while for the RPM to drop before letting out the clutch to have a smooth shift. same with 2nd to 3rd, though less time than from 1st to 2nd. 3rd to 4th and above is perfect. you might just need to shift faster but considering you're new to manual, you'll get the hang of it eventually. and if you have AC on, the RPM's do drop faster so that might also be why. with AC on, my RPM's always drop when shifting into 5th and above unless I actually focus on shifting fast. I just ease the clutch in to have a smooth shift but it's not a major jump anyways, probably around 300-500 RPM.
I would also recommend you adjust your clutch pedal since the stock position at the very beginning of the pedal sucks. I adjusted mine to be closer to 3/4 of the pedal travel (closer to the floor). it makes it easier to drive, especially if you're new to manual.
Old 06-29-2016, 10:27 PM   #5
humfrz
Oh, just get it broke in ........ then shift above 4,000 rpms ........you'll get the hang of it .....
New engine + new transmission + new MT driver = takes some breaking in and getten used to
humfrz
Old 06-29-2016, 11:13 PM   #6
trigun286
trigun286's Avatar
Yea, it definitely is the same for me from 1st to 2nd. But the drops are crazy from then on. And 4th to 5th is super jerky if I don't shift fast. I guess I'll focus on shifting a little faster from now on. It just seems weird to me to do that when I'm just cruising around.
I have been noticing that I'm riding the clutch a little too much. I read elsewhere that removing the helper spring would help with clutch feel. I tried to remove it but it proved tougher than I thought.
Sent from my Nexus 9 using Tapatalk
Old 06-29-2016, 11:46 PM   #7
ryoma
ryoma's Avatar
I left my spring in. I adjusted the clutch the minute I pulled the car into my garage after I took it from the dealership. here's a thread on how to do it: http://www.ft86club.com/forums/showthread.php?t=8040 it is extremely easy.
Light weight flywheel and crank pulley? wootwoot Engine, Exhaust, Transmission 133 06-23-2015 01:04 PM
Has anyone install a light weight flywheel? 20valvewynn83 Engine, Exhaust, Transmission 44 08-08-2013 09:52 PM
Which light flywheel with stock clutch? diss7 Engine, Exhaust, Transmission 4 05-01-2013 09:47 PM
Evolution Industries Light weight Flywheel :) 20valvewynn83 Engine, Exhaust, Transmission 6 12-14-2012 05:35 PM
Sard light weight flywheel Turdinator Engine, Exhaust, Transmission 4 10-30-2012 08:53 PM
