Old 05-01-2013, 09:08 PM   #1
diss7
Drives: AE86, 2x GT86, TE27
Which light flywheel with stock clutch?
I'm considering 'trying' an NA setup, seeing as I'm still so undecided about FI.
I'd like to try a lighter flywheel, but retain the stock clutch. Also, I'd like the same flywheel to be able to be used with an upgraded clutch, should I end up going FI and requiring one.
Any tips on which flywheel fits the above requirements? (Or do they all??)
Thanks.
diss7 is offline   Reply With Quote
Old 05-01-2013, 09:11 PM   #2
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
they probably all fit. flywheels will retain the same bolt and pin pattern as stock ones
IG-Joey_Soul
Old 05-01-2013, 09:20 PM   #3
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
FWIW, my act prolite flywheel is completely streetable. My car idles just fine. When I took the flywheel to a professional balance shop, they said it was balanced just fine. The clutch cover on the other hand... had it balanced as an assembly.
No issues, just some extra noise/chatter here and there.
industrial is offline   Reply With Quote
Old 05-01-2013, 09:31 PM   #4
xjohnx
Grip>Slip
xjohnx's Avatar
are you doing the install yourself? if not, i'd recommend you have them put a clutch in while they're at it. Especially if you're thinking you may want to go FI down the line. No point in paying for the labor twice.
Old 05-01-2013, 09:47 PM   #5
diss7
Thanks for the quick replys. Answered all my questions, even the ones I didn't ask.
Stock Clutch/Flywheel For Sale Supermassive Transmission and Driveline 9 07-01-2013 05:49 AM
GI: Stock FLywheel and clutch jwjknorr Transmission and Driveline 2 04-15-2013 07:38 AM
Special Deals on Clutch Masters Clutch & Flywheel Combo! KronosPerformance Transmission and Driveline 15 08-25-2012 12:22 PM
Clutch Masters Clutch and Flywheel Kits for FR-S and BRZ available at Redline360 Redline360 Transmission and Driveline 2 07-30-2012 10:01 AM
