Old 06-25-2016, 07:40 PM   #1
Hugo
Drives: Toyota 86
Mishimoto catch can or Radium
Hey guys,
I need help deciding between the 2. The mishimoto baffled catch can or the radium PCV catch can? My car will be NA for the time being and for quite a while. I've searched on this forum that you would mainly require the PCV side only. Also upon research i've nailed it down to these to catch cans because it seems like both are right up there if you were to buy a catch can. I also understand the radium isn't baffled and obviously the mishimoto is.
Any other differences and reasons as to which one to get?
Thank you, any help much appreciated!
Hugo is offline   Reply With Quote
Old 06-25-2016, 08:27 PM   #2
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
If you NA and a daily driver I wouldn't bother. Track and boost gives us a lot of blow by. Easy way to see if you really need one is to pull your intake off and look at your throttle body. If you see no oil, then invest the money elsewhere.
I personally made my own and saved hundreds. Google your friend.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 06-25-2016, 10:19 PM   #3
ryoma
ryoma's Avatar
I bought the Radium because I liked the look of it (and the fact that they are big in the Lotus scene) lol. I only bought the PCV side though. I have yet to check the dipstick to see how much oil accumulated over the last few months, if any.
Old 06-26-2016, 02:56 AM   #4
SoCalArgento
Drives: 2014 Argento FRS
I too got the Radium Dual cuz they look nice, offer the dipstick and had great reviews from what I read. I got both since I'm FI. Back when I was NA the PCV side collected some but significantly more with FI.
SoCalArgento is offline   Reply With Quote
Old 06-26-2016, 03:53 PM   #5
RJasonKlein
RJasonKlein's Avatar
They're very different designs aesthetically, but both function identically - it really comes down to the look you're after. I went with the Radium unit and like it very much.
RJasonKlein is offline   Reply With Quote
Old 06-26-2016, 08:44 PM   #6
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Saikou Michi
Old 06-26-2016, 09:13 PM   #7
DAEMANO
Time Traveller
Also they mount in different places, which was an important factor when I chose Mishimoto. I would have preferred the Radium setup if it didn't mount where it does.
Old 06-27-2016, 06:00 AM   #8
Hugo
Drives: Toyota 86
Hmm, so i either will do depending which mounting location you prefer.. How about the racer X catch can?? They look very well built too, anyone care to share their opinion on this can? Obviously this one is a little more dearer but takes care of both crankcase and PCV?
Old 06-27-2016, 11:28 AM   #9
Apex-Apex
Apex-Apex's Avatar
Radium
Varis 2JZ Build Thread
IG: @apexapexapex
Apex-Apex is offline   Reply With Quote
Old 06-27-2016, 01:31 PM   #10
Muller Performance
Muller Performance's Avatar
Drives: Subaru & Scion
Radium for sure.
Muller Performance is offline   Reply With Quote
Old 06-27-2016, 03:01 PM   #11
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
I chose the dual Radium set-up due to what I think was better internalle baffling since it looked to have more surface area for oil to adhere to and therefor keep more from getting back to the motor
Old 06-27-2016, 03:19 PM   #12
Kestrel
Kestrel's Avatar
Drives: 2015 Ultramarine FR-S AT
Racer X NA motor user here. The unit pulled a good amount of oil out of recirculation by my first servicing. It's also the most sexy set up so it gets my vote.
Sent from my SAMSUNG-SM-G900A using Tapatalk
Kestrel is offline   Reply With Quote
Radium catch can routing info ft86me Engine, Exhaust, Transmission 6 09-16-2016 12:09 PM
FS: Radium Crankcase Catch Can blueap2 Engine, Exhaust, Bolt-Ons 5 07-01-2016 01:39 PM
WTB: Radium PCV Catch Can mb_ Want-To-Buy Requests 0 06-11-2016 12:40 PM
Radium Catch Can - $150 - SOLD TemeCal Engine, Exhaust, Bolt-Ons 2 02-04-2015 09:59 PM
FS: Radium Engineering Catch Can (SOLD) SuiSid3l Engine, Exhaust, Bolt-Ons 3 12-15-2014 04:34 PM
