Old 06-22-2016, 12:56 AM   #1
Mikeez
Engineering Student
Drives: Scion FR-S 2015
How do I remove this bolt o.o?
Hey guys,
Okay so this bolt is attaching the wheel well and the front bumper. Since our wheel well is made of plastic/rubber....
Here is some pictures. I tried a Philips screw driver and a ratchet (10mm) but both don't work as it ruins the wheel well.
Do not worry about what I am doing please.
Also at 2:28 of this video. This guy is removing the bolt easily with a philips. However, when I do it with a lost of force. It turns the whole wheel well...
Also as I was taking the wheel well... few washer fell off. Anyone can tell me where it goes. It came from the front. If you need more description. Let me know.
There’s no time to stop for gas, we’re already late
Mikeez is offline   Reply With Quote
Old 06-22-2016, 01:27 AM   #2
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Originally Posted by Mikeez View Post
Hey guys,
It seems alot of people have issues with that one, I haven't it sort of just unscrewed out of its hole. I think someone else here just drilled it out and found push pins online to replace the bolt with.
Old 06-22-2016, 02:59 AM   #3
ryoma
ryoma's Avatar
is the bolt necessary to remove when taking off the bumper? I don't remember removing it when taking off my bumper, but if I did, it didn't give me any problems at all. have you tried some pb blaster?
Old 06-22-2016, 03:05 AM   #4
humfrz
You might try using a pair of vice grips and pull down on it as you are unscrewing it.
humfrz
Old 06-22-2016, 08:36 AM   #5
pooch
pooch's Avatar
Drives: 2013 Scion FR-S (M/T)
Most likely it's rusted to the U Nut on the other end that's what you're experiencing, lube it up because you might tear the plastic, but you might have to and just DIY a fastener after your project is done but I don't have the bolt there anymore and it holds up fine for regular driving.
pooch is offline   Reply With Quote
Old 06-22-2016, 08:38 AM   #6
pooch
pooch's Avatar
That's basically whats on the other side
How to remove seat rail bolt after you've stripped it protpibe DIY (Do-It-Yourself) Guides 33 02-01-2020 02:06 PM
Camber bolt + suspension bolt torque settings LostSalad DIY (Do-It-Yourself) Guides 3 05-09-2016 09:29 AM
FI Hood insulation: To remove or not to remove bryan767 Forced Induction 8 08-15-2015 04:51 AM
will polishing your car to remove swirls remove opti-coat? bacon_cheese_beer Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 11 10-25-2012 10:41 PM
BRZ crash bolt same as Impreza lower strut bolt? xwd Tracking / Autocross / HPDE / Drifting 0 07-05-2012 12:19 PM
