Old 06-20-2016, 07:09 AM   #1
Codythatsme
Drives: GT 86
Tyre Stretch, make ride higher? Bulgy tyre
Hey guys, so I'm running the Airlift Performance kit and so is one of my friends, although when aired out his front touches the ground where as I still have a bit of clearance.. I've been trying to work out what causes this. Both struts are adjusted to the same height, and running the same camber from the top camber plate.
His specs are 18x9.5 with 215/35
My specs are 18x10 with 225/35
So similar stretch for Both wheels. Just from looking at both cars, the way my tyres sit on the wheels.. They seem to be bulgy? Like they're fatter, not sure if I'm just imagining it as I'm not an expert in tyre stretch.. But is there anyway the tyre can be bulged when stretching on resulting in the car sitting higher?
Codythatsme is offline   Reply With Quote
Old 06-20-2016, 07:43 AM   #2
Cole
Not a troll
Cole's Avatar
Your tire is wider and has the same ratio as his, so it will be a little bit taller
Old 06-20-2016, 07:51 AM   #3
Codythatsme
Drives: GT 86
Thanks man, just a bit confused how that works, should being wider (225 instead of 215) not affect height at all? Jus trying to visualise how that works.
Old 06-20-2016, 08:01 AM   #4
Cole
Not a troll
Cole's Avatar
Read this, and if you still don't get it, google more about how tire size works.
Normally, tires are sized as 245/40/17. Where, 245 is the width, 40 is the aspect ratio, or sidewall height and is a percentage of the width of the tire. And the 17 is your wheel diameter.
Old 06-20-2016, 10:56 AM   #5
-Willis-86touge
Drives: Stock
No, the 35 in the number refers to 35% of the width with on the 215 would be 75 mm and on the 225 would be nearly 79 mm. So the 225 wheel is 4 mm taller then the 215 hence why it looks "bulgy" also the 225 itself is wider. Also you never stated if they were the same brand. Brands can vary on size. Check tire rack under the specs sheets. Your tire maybe 2or 3 mm taller or wider due to the manufacturer.
-Willis-86touge is offline   Reply With Quote
need help with tyre sizes ELLEENN AUSTRALIA 1 04-26-2015 07:30 PM
Tyre Opinions Karl07 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 09-03-2013 06:52 AM
Tyre Thoughts Captain Snooze AUSTRALIA 15 02-24-2013 08:44 PM
Tyre pressures st162celica AUSTRALIA 6 08-08-2012 05:25 AM
Tyre you will be getting Staticfrost AUSTRALIA 38 06-22-2012 09:02 PM
