Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AUSTRALIA
AUSTRALIA Australia and New Zealand
Old 08-07-2012, 10:16 AM   #1
st162celica
Drives: 86 GTS Manual - Tornado Grey
Tyre pressures
35psi front and back for both 16" and 17" wheels is recommended in the Brz manual.
I always run about 5-6psi more on the front and 4-5 more on the rear. Running my tyres like that seems to get me the most even wear across the tyre. I tend to corner fairly heavy in both my cars and the it's just feels sharper with higher psi.
Downside running higher psi is hitting Sydney potholes and lower wet weather grip.
What is everyone running ? (or thinking of running)
st162celica is offline   Reply With Quote
Old 08-07-2012, 05:15 PM   #2
Nardi330
Nardi330's Avatar
Drives: 86
I think 35 front and back are good enough.
Nardi330 is offline   Reply With Quote
Old 08-08-2012, 01:12 AM   #3
Panman
Panman's Avatar
Drives: 86 GTS
I like to run a couple of PSI higher in the front that the rear normally, it gives sharper turn in (front sidewalls stiffer), flex in the rears gives a little additional assist, and of course there's more weight on the fronts.
It's a car-by-car thing though so will wait until I've got the car and tested a few variables before I make a statement definitively, on the Elise I ran equal pressures and it was fine.
Panman is offline   Reply With Quote
Old 08-08-2012, 01:28 AM   #4
Xauterus
Drives: GTS 86 Galaxy Blue
My wheel alignment guy recommended 40front and 38 rear. He said the factory tend to err on the soft side for road comfort for the average driver. If you are not just a poser, then the extra is probably worthwhile.
He has a good racing background.
I figure most tyres are gradually leaking too so it helps to be up a touch.
Track use is a whole other matter as far as pressures go.
Xauterus is offline   Reply With Quote
Old 08-08-2012, 01:50 AM   #5
Nardi330
Nardi330's Avatar
Drives: 86
40F/38R is that cold pressure??
that's high for street use i reckon.
Old 08-08-2012, 02:35 AM   #6
st162celica
Yes. Tyres should be filled while cold.
I even saw the recommendation in the NRMA magazine a few years back. They recommended running 5-6PSI more than standard. There was a comment after that statement that explained the lower wet weather grip due to the less flex in the side walls. etc.
My dad has a front heavy camry. I always told him to pump themp up more but he always used the standard and was chewing through tyres too quickly. and still is.
Still heaps of tread down the middle but the sides virtually bold.
My Brother has a MR2 spyder. When he picked it up from Toyota NEW the tyres were pumped to 50psi front and rear. The car handled really well. After 6 or so months he noticed they were wearing out through the middle quite alot but not the sides. So told him to keep them around the 40 mark and his new tyres have been wearing evenly ever since. Still handles really well on 40psi. Its a spyder. Life size go kart.
Old 08-08-2012, 05:25 AM   #7
Nafe
Nafe's Avatar
Drives: Mt Fuji Red 86 GT
I always put my tyres at 40psi all round.
Nafe is offline   Reply With Quote
Tyre load and speed rating Nardi330 AUSTRALIA 8 06-28-2012 06:26 AM
Tyre you will be getting Staticfrost AUSTRALIA 38 06-22-2012 09:02 PM
