Old 06-18-2016, 03:13 PM   #1
hachi roku [86]
Drives: Toyota GT86, Mazda MX-5 NB
Mechanical sound - rear axle or rear brake disc?
After working on the rear passenger-side wheel to replace the wheel studs started hearing vibration / noises like this: [ame="http://youtu.be/DTufUXuZwnk"]http://youtu.be/DTufUXuZwnk[/ame]
I have a bad feeling that I might have applied to much pressure to the axle while trying to remove the hub with the studs, damaging the axle. However, it might also be smth wrong with installing the old brake disc back on, especially since the noise seems to fade when I apply the brakes (can be also heard in the video).
Is there some science about how to balance the brake disc, or have I indeed wrecked the rear axle?
hachi roku [86] is offline   Reply With Quote
Old 06-18-2016, 10:15 PM   #2
Ultramaroon
not playing cards
Ultramaroon's Avatar
I think you might be onto something regarding the rotor but it's a tough call. Good recording.
Maybe try putting it back up on stands and rotate the wheel by hand while it's in neutral?
Old 06-19-2016, 01:56 AM   #3
humfrz
Then you might consider taking it back apart to look for something lose. I'd pay special attention to the emergency brake.
Is the axle nut tight .. ??
humfrz
Old 06-21-2016, 11:41 AM   #4
hachi roku [86]
The lug nut is seems tight (very), tightened with an air impact, although I don't have the right torque wrench.
Will try to take the disc off and back on, and check the E-brake...
Old 08-05-2016, 06:26 AM   #5
hachi roku [86]
For those wondering, it turned out to be completely unrelated to the whole rear axle / axle nut issue. I just haven't tightened the lug nuts well enough on the opposite wheel :-P
Old 08-05-2016, 04:02 PM   #6
humfrz
....... now, that's once!
But thanks, for getting back to us ......
humfrz
Old 08-05-2016, 04:23 PM   #7
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
thank that it didnt get loose while you drove.
Old 08-05-2016, 05:42 PM   #8
iamjacob
insert witty quip here
Drives: 2016 Limited BRZ
Happened to me once on my very first car a 1980 Dodge Ram 50. Lost 2 out of 6 nuts and nearly lost the wheel.
Double check all your lug nuts folks, every nut, every time.
Gald you found it in time.
iamjacob is offline   Reply With Quote
Clicking Sound From Rear (Axle?) gonzo Issues | Warranty | Recalls / TSB 9 02-09-2020 12:26 PM
FS: Rear tow hook and Rear LED brake light damaster32 Exterior Parts (Aero, Lighting, Etc.) 4 01-21-2016 12:46 PM
Mechanical Sound Coming from rear hotfootpowder Engine, Exhaust, Transmission 3 05-24-2015 02:24 AM
WTB: REAR window top Brake Light (just top half with leds) or full rear deck Kayzer Soze Exterior Parts (Aero, Lighting, Etc.) 1 08-31-2013 02:23 PM
Rear Parking Brake Guard Rub (Meaty Rear Tires) console_cowboy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 08-13-2013 02:39 PM
