Old 08-13-2013, 12:04 AM   #1
console_cowboy
console_cowboy's Avatar
Drives: 2013 Black BRZ Limited
Rear Parking Brake Guard Rub (Meaty Rear Tires)
So I'm running +45 offset 18x9.5" wide wheels with 255/35/18 tires and I am having a slight issue with my wheels rubbing against the parking brake guards during high G cornering. If anyone hears a very slight metallic rub noise from the rear during cornering, I would be fairly sure it is this. I am considering bending them out of the way, but there doesn't seem to be much room there. Has anyone else had this problem when running larger wheels? I've got an autocross this weekend and would like to get this fixed before (by bending or such) then. I'll be glad to take some photos tomorrow if anyone is interested. Thanks!
console_cowboy is offline   Reply With Quote
Old 08-13-2013, 10:16 AM   #2
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I looked at those when I installed my 18x9.5 +40 265/35/18, and I removed them and bent them with my vice. Since you are running 5mm less offset, it does not surprise me that you are rubbing them.
Old 08-13-2013, 10:34 AM   #3
Sookainian
Sookainian's Avatar
Drives: Toyota GT86
May i please know what is a rear parking brake guide rubber ? do you have any photo of it ? Thanks
Sookainian is offline   Reply With Quote
Old 08-13-2013, 10:35 AM   #4
ZionsWrath
Thanks
ZionsWrath's Avatar
What tire are you running? Stock height?
I run 9.5 +45 rear with continental 255/35/18 no rub but they run narrow and im stock height.
Old 08-13-2013, 11:08 AM   #5
TrogDor the Burninator
TrogDor the Burninator's Avatar
Drives: 2013 Hot Lava FR-S 6 MT
I had the same issue with my TE37SLs 18x9 +45 with Dunlop Direzza ZIIs 255/35. Rubbed on the right rear wheel (grrrr). I also took the brake line guard off and bent it.
2013 Scion FR-S Hot Lava 6MT Current Mods: KW V3 Coilovers - Raceseng CasCam Plates - Volk TE37SL Black Edition 18x9 +45 - Dunlop Direzza ZIIs 255/35 - Tomei Expreme Ti 60S - FT86 SpeedFactory UEL Catted Header
TrogDor the Burninator is offline   Reply With Quote
Old 08-13-2013, 11:19 AM   #6
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
interested in pics showing exactly what to bend, too. haven't had the issue yet, but good to know what to bend if i encounter it.
shiumai is offline   Reply With Quote
Old 08-13-2013, 11:49 AM   #7
King Tut
NASA SpecE30 Racer
King Tut's Avatar
It mounts to the rear lower control arm with one bolt and the parking brake line on each side kind of rests on it. The bracket has a loop on top of it to keep the parking brake line from getting into the wheel/tire. You simply remove the bracket and bend that loop to get more clearance. It is easy to see if you have clearance by looking under your car from the rear.
Old 08-13-2013, 02:39 PM   #8
console_cowboy
I am running 255/35/18 tires with RCE Yellow springs. I had no trouble before lowering, so I am sure that is part of the issue. I'm using Kumho Ecsta LE Sport tires, and I am honestly not sure if they run thin or wide. The actual rubbing seems to be on the wheels themselves, so I will try to bend those tomorrow if the weather agrees. Good to know several other people have had to do this. I'll take photos when I bend them for anyone who wants to see. Thank you for the replies.
EDIT: They don't rub at all unless I am doing some hard cornering. Its quite easy to avoid rubbing them unless autocrossing or something of that sort.
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 09-09-2015 06:32 PM
rear brake pads donutfilling Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 04-05-2013 10:43 PM
rear brake light in the rear fog light section FR-Shadow Cosmetic Modification (Interior/Exterior/Lighting) 34 12-13-2012 10:52 AM
FR-S Rear brake light... MF_DEUCE FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 70 05-05-2011 03:53 PM
Secondary Rear Brake Caliper for drifting or parking brake?? (pics) Axel Scion FR-S / Toyota 86 GT86 General Forum 20 02-25-2010 10:28 AM
