Old 08-21-2014, 02:51 PM   #1
gonzo
Drives: frs
Clicking Sound From Rear (Axle?)
I finally took a video where you can really hear the click. It has been clicking more consistently the past few weeks (clicking started 9 months ago) and it now sometimes clicks into second and third gear. Toyota dealer said they have no idea what it is (according to them it's a Subaru so they don't know the car). Any help?
[ame]http://youtu.be/OZoN6mWBgro[/ame]
gonzo is offline   Reply With Quote
Old 08-21-2014, 02:53 PM   #2
gonzo
Drives: frs
In this video I am slowly taking off in first, but it also happens when engine braking by taking foot off throttle in first.
Old 08-21-2014, 03:20 PM   #3
strat61caster
strat61caster's Avatar
Have you tried re-torquing the axle nuts?
Should be a fifteen minute job at the dealership from what I've heard, should fall under the powertrain warranty (5 years, 60,000 miles). Several people with a clicking noise from the rear end have had this done with success.
Old 08-21-2014, 03:33 PM   #4
gonzo
Drives: frs
I told them to do exactly that. Instead they tightened the bolts on my slid plate and engine cover, lol. Then they said the car's a subaru and they don't have any experience with it.
Same dealer also told me the clutch squeak noise is normal and they don't want to replace the clutch.
I'll go back again and tell them, once again, to tighten the axle nut. I'm worried it's the axle.
Old 10-06-2014, 11:43 PM   #5
wonton19
Drives: 2000 ford focus zx3 kona
had the same issue, took it to the dealer, they said it was a loos axle nut. the replaced and resecured it..so far havent heard the clicking sound
wonton19 is offline   Reply With Quote
Old 10-07-2014, 04:40 PM   #6
WillRacer1jz
Drives: 1987 JZA70 Supra, 2013 FR-S
FYI
http://www.ft86club.com/forums/showt...licking&page=2
WillRacer1jz is offline   Reply With Quote
Old 10-13-2014, 02:54 PM   #7
Chris_
Drives: 17 BRZ PP
Had the same issue, removed axle nuts, swapped left and right (so the stake is in a different spot), and torqued to specification.
Temporary fix while I had new axle nuts on order (they are one time use and should be replaced when removed according to the service manual).
Fixed the clicking noise.
Chris_ is offline   Reply With Quote
Old 10-17-2014, 02:44 PM   #8
WillRacer1jz
I just had a second axle replaced this week. My left axle was replaced at 15k and the right axel at 35k miles under warranty for cracks.
Old 10-29-2014, 02:42 AM   #9
Clott
Clott's Avatar
Drives: 2013 Raven FRS(Sold): Fiesta ST
How often did you hear the clicks? Mine is making a weird clicking sound when either reversing, after I'm in 1st, and after I'm in 2nd. Its odd. Taking it to the dealer in the morning.
Clott is offline   Reply With Quote
Old 02-09-2020, 12:26 PM   #10
Inteze
Drives: Toyota GT86
I have the same issue I think, have you found a fix or what it was ? Thank you
Inteze is offline   Reply With Quote
FRS Clicking/Tapping sound DCStorm Issues | Warranty | Recalls / TSB 30 12-29-2017 09:59 AM
What is this clicking sound coming from under the rear of my car? stockysnail Engine, Exhaust, Transmission 57 09-14-2016 07:17 PM
ATfaint to moderate clicking sound in cabin Shimmyshake Issues | Warranty | Recalls / TSB 15 05-21-2014 12:26 AM
Clicking sound at idle from engine bay? l0aded Issues | Warranty | Recalls / TSB 2 08-13-2013 02:26 PM
GTS rear left popping/clicking sound and fix. sigmaoctantis AUSTRALIA 11 05-19-2013 06:58 AM
