Old 12-11-2013, 11:09 PM   #1
VITA
Lady on RWD
VITA's Avatar
Drives: Toyota FT-86
Exclamation [HELP] Rear Wheel Bearings
my car (Toyota FT86) is making a noise, and everyone says that's a Rear Wheel Bearing problem
(Rodamiento de Rueda/Maza)
mechanic said that he can't disassemble because if its broken
he cant put all together again in that condition
so first.. I must get the Bearing
anyone knows what bearing CODE is?
part number/Bearing # .... any?
so I can get only the sealed Bearing and change them, both sides.
I called Toyota and they said: SU00300791
but is a complete Hub part #
I found this photos and at least I can change ONLY the bearing
and not the complete Hub
Any help will be appreciate
Photo source: internet - from a FRS/BRZ
(I believe on 3 cars are same parts)
Thanksss!!
VITA is offline   Reply With Quote
Old 12-12-2013, 12:04 AM   #2
DOTman05
Drives: Evo 8
You don't need that whole assembly pictured
Just need the wheel bearing and hub unit
Let me know if you need part number I work for the dealer
DOTman05 is offline   Reply With Quote
Old 12-12-2013, 12:07 AM   #3
Mo707
Mo707's Avatar
I work at toyota, if i remember ill look it up tomorrow.!
Mo707 is offline   Reply With Quote
Old 12-12-2013, 12:57 AM   #4
Dezoris
Dezoris's Avatar
You need: 42450A and 42450B (SU00300791 and SU0030079)
42311N 42312B
http://www.villagescionparts.com/sho...rimLevel=24532
Enjoy @VITA don't say I never helped.
Old 12-12-2013, 09:29 AM   #5
VITA
Lady on RWD
VITA's Avatar
i cant get the Bearing code number
i need that.. just that
so i can buy same bearing
i don't have part numbers, just this photos
Old 12-12-2013, 09:36 AM   #6
VITA
Lady on RWD
VITA's Avatar
THANKSS !!!!
42311N 42312B
yes, that's the closest thing i found
but i just need the Bearing
not the whole thing
problem is that i need the Bearing code/part number
example:
Old 12-12-2013, 12:51 PM   #7
Dezoris
Dezoris's Avatar
You won't find just the bearing from subaru or toyota on this its a one piece assembly. You have to go after market bearing which is not a good idea for this part. Pressing out the old bearing and trying to get a new one in without damaging it will be almost impossible.
The labor involved in doing that anyway would be probably equal to just buying the new hub. Is this just a cost issue?
Old 12-12-2013, 01:04 PM   #8
s2d4
s2d4's Avatar
What is so different about these wheel bearings?
Old 12-12-2013, 01:48 PM   #9
VITA
Lady on RWD
VITA's Avatar
yes!
132 x 2 pcs = 260
+ 150 shipping = $400
(shipping 20 days)
NSK - SKF or any GOOD bearing ...50$
(shipping 20 mins)
sorry, im in the wrong side of the world
thats why im searching for it
btw.. your solution is the best, for sure
in that case, of course
Old 12-12-2013, 01:50 PM   #10
VITA
Lady on RWD
VITA's Avatar
some guys told me that Bearings are same than Subaru WRX 02-07
but..im trying to ask the boys here
maybe i found some who had the same problem before
Old 12-12-2013, 01:51 PM   #11
OrbitalEllipses
Drives: Attitude
Is this not covered under the Toyota's limited warranty in Argentina?
08+ actually. The bolt pattern is the same as 02-07, but the hub is from the 08+ rear suspension.
Old 12-12-2013, 04:30 PM   #12
Dezoris
Dezoris's Avatar
yes!
132 x 2 pcs = 260
(shipping 20 days)
(shipping 20 mins)
I take for granted your location, as it would be easy for me to eat the $260 US and install myself vs. pressing in new.
I realize now based on your location that cost doubles.
To save the costs now you are unfortunately having to find comparable bearings. The current gen Imprezza has the same style rear suspension. You have to go back to the 2007 model year to find press in wheel bearings from Subaru. Whether they are the same size are not is a gamble.
Old 12-12-2013, 05:04 PM   #13
Mo707
Mo707's Avatar
SU003-00791
$187.94 AFTER TAX IN CA
EDIT: CANT GET JUST THE BEARING. ITS THE WHOLE ASSY.
Old 05-03-2019, 05:44 PM   #14
LotsaMiles
Drives: Scion FR-s, xB, iA, Silverado Z71 4
SU003-00791
What a difference a few years makes. I hit the business end of a 4x4 a few years ago in my FRS. It damaged the front wheel, tire and front bearing. I had the dealership replace it. Oddly, though the rear wheel ht it, it was not damaged.
Well, at 164k miles, it's bad now. But I just went to amazon and got it for $65. Two for $120. OEM (not the cheap one).
In just a few short years getting this part has gone from "what do I do now?" to Order it on Amazon. And I even found a video describing how to do it:
[ame]https://www.youtube.com/watch?v=cBRsE72LqzI[/ame]
LotsaMiles is offline   Reply With Quote
PAUTER ROD WITH ACL RACE BEARINGS cf6mech Engine, Exhaust, Transmission 48 09-22-2014 12:01 AM
The OEM rod bearings debate nelsmar Engine, Exhaust, Transmission 58 12-02-2013 12:51 PM
Fortune Auto V4 500s W/ Roller bearings FR-S86 Brakes, Suspension, Chassis 21 02-12-2013 03:30 PM
FRS-off/rear wheel buzzing... iaclimber4 Scion FR-S / Toyota 86 GT86 General Forum 4 01-31-2013 06:25 PM
Subaru BRZ rear wheel drive - WHY? Hawk77FT AUSTRALIA 86 11-25-2012 06:37 PM
