Old 06-07-2016, 02:10 PM   #1
Astroboy
Astroboy's Avatar
Drives: None
Any thoughts about royal purple max gear for transmission?
Anybody else on here running royal purple max gear fluid in their fr-s? Or does anybody have any thoughts about it? I am only asking because i recently put it in my transmission after I swapped out the clutch and was just wondering if its ok for the trans. Royal purple stated that MaxGear can be ran as gl4 or gl5, which I find kind of odd. I even called RP to see if it will be fine for my trans and they told me it will.
Sent from my LG-D850 using Tapatalk
Astroboy is offline   Reply With Quote
Old 06-07-2016, 03:43 PM   #2
sheady
Drives: 2013 Ultramarine FRS
I'm using RP in my transmission and have had no issues. I've driven a couple thousand miles since the swap and have gone through twisties, 2 autocross events, and a track day. Make sure you're using the 75w90.
sheady is offline   Reply With Quote
The Following User Says Thank You to sheady For This Useful Post:
Astroboy (06-07-2016)
Old 06-07-2016, 05:46 PM   #3
Astroboy
Astroboy's Avatar
Drives: None
Thanks! Are you using the Max gear line too?
Sent from my SM-T710 using Tapatalk
Old 06-07-2016, 06:36 PM   #4
sheady
Yeah, I originally was going to use the Motul that most recommend here on the forum, but was time constrained in sourcing my oil (no prime shipping on amazon for it). Autozone had the RP and I have no complaints so far.
Old 06-07-2016, 10:24 PM   #5
Astroboy
Astroboy's Avatar
Drives: None
Same here. I had the clutch in and ready to go, but I was not going to wait days do try out my new clutch. Well, good to know its holding well for your car especially on how you use it, makes me relieved.
Old 06-08-2016, 01:25 PM   #6
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
My experiences with RP have been bad generally.
My friends 2000 RS has an 04 STi trans and developed a 5th gear grind. We drained the fluid and replaced with RP.
Gear grind was worse.
Swapped with cheap advanced auto castrol, gear grind was gone completely and felt better.
The RP felt very thin in hand.
Look for Motul locally if you can is my opinion, though some people have definitely has good results with RP.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
The Following User Says Thank You to JazzleSAURUS For This Useful Post:
Astroboy (06-08-2016)
Old 06-12-2016, 04:49 PM   #7
Astroboy
Astroboy's Avatar
Drives: None
Any gear grinding issues? In higher rpms?
Royal purple tran oil review MyNave Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 06-08-2016 04:25 PM
Any Issues with Royal Purple? akuhei Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 46 08-03-2015 05:06 PM
Royal Purple for Manual Transmission jetrex Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 9 06-27-2015 03:05 AM
Royal Purple Oil - Possible GB (Vic Only) fuddbutter Australia Classifieds 0 11-14-2012 08:48 PM
Oil Change - Perhaps Royal Purple? RowTarEEE Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 47 11-01-2012 06:47 PM
