Old 11-07-2012, 06:33 PM   #1
akuhei
akuhei's Avatar
Drives: Raven M/T FR-S
Any Issues with Royal Purple?
Has anyone run into any issues with running Royal Purple in their BRZ/FRS? I've seen a lot of bashing their oil on the forums from people who used to use it, but nobody who's run it on this engine seems to be saying anything good or bad. I hate to make a decision based on old information from different engines.
Akuhei's Blog
"Inconceivable"
akuhei is offline   Reply With Quote
Old 11-07-2012, 06:41 PM   #2
zoomzoomers
zoomzoomers's Avatar
Drives: 2013 Subaru SWP BRZ Limited 6AT
I've been running RP 0w20 in my car for about a 1k miles. I've literally had zero issues with RP. If anything, my motor seems to be running smoother and quieter. I've also lost the crickets, although I can't be sure that it's the oil that's fixed that. So far, RP get's a thumbs up from me. Also, zero oil lost since the change.
Man Law#17:A man in the company of a hot, seductively dressed, woman MUST remain sober enough to fight!
MODS: AVO tubes + filter, Cusco (F) strut brace w/ MC brace, Perrin CBE, Subaru OEM trunk tray, Grimmspeed front license re-locator & hood struts and Beatsonic rear cam.
zoomzoomers is offline   Reply With Quote
Old 11-08-2012, 05:59 PM   #3
brillo
Drives: 2013 Firestorm FR-S
I've used RP in my RX8 for 8+ years with no issues and I get better mileage than most RX owners. I've had good luck with Redline products as well. There are alot of good higher end synthetic oils out there (Amsoil, Redline, RP) but I use RP based on past history and as they are local (I've met the engineers at RP personally).
brillo is offline   Reply With Quote
Old 11-08-2012, 06:16 PM   #4
RRnold
2 wheel member
RRnold's Avatar
Drives: JZA80, 997.1, Taco
What can possibly go wrong by switching to a different motor oil on an new N/A motor?
Old 11-08-2012, 06:27 PM   #5
akuhei
akuhei's Avatar
There are countless threads stating that RP has had problems in any of Subaru's other/older boxer motors. Just that it didnt run right or whatever. At the same time, those are based on different motors, so I was hoping for (and got) some feedback on our motor. I appreciate everyone's inputs by the way.
Akuhei's Blog
"Inconceivable"
Old 11-08-2012, 07:28 PM   #6
blu_
blu_'s Avatar
Drives: SWP BRZ LTD
It's debatable. I used to be on the royal purple sucks bandwagon... I dont think its terrible anymore, probably better than most oils.
BUT its still a semi overratted oil for the price if you look at bobistheoilguy.com. There are better oils to use out there if you are looking to put the most high tech oil into your car.
For an NA engine, if you arent tracking it, I dont think its a big deal which ever way you go.
blu_ is offline   Reply With Quote
Old 11-08-2012, 07:31 PM   #7
akuhei
akuhei's Avatar
I get a discount on base (and no tax is a plus as well), so I wanted to be sure that nobody has had problems. I dont think I'm going to be doing tons of racing quite yet (though I am trying to do more and more as the opportunities present themselves nearby). So i figure it will probably do the trick without paying the $80-90+ for motul.
Akuhei's Blog
"Inconceivable"
Old 11-08-2012, 07:32 PM   #8
blu_
blu_'s Avatar
Drives: SWP BRZ LTD
Also subaru boxer issues with it arent nearly as bad as Mobil 1. I had a friend run royal purple for years on his STI with no issues.
Old 11-08-2012, 07:34 PM   #9
blu_
blu_'s Avatar
Drives: SWP BRZ LTD
It should be fine... hell I have Valvoline in my BRZ right now and will probably switch to the Subaru synthetic next oil change just to save money. I am fairly anal about my car too.
just watch consumption...
Old 11-08-2012, 07:47 PM   #10
michaelahess
michaelahess's Avatar
Drives: '13 GBS BRZ Lim, 2006 Dodge RAM MC
Been running fine in mine for a thousand miles or so already.
michaelahess is offline   Reply With Quote
Old 11-08-2012, 08:40 PM   #11
Ravenlokk
Ravenlokk's Avatar
Drives: 2013 Raven FR-S
I've used RP on my past cars with no issue. I a bunch of different weights depending on season etc on my skyline, same with gto. I also used it and a variety of other oils in my yaris with no issue. No issues switching to different oil types (lolyaris, so whatever oil was on sale :P). My experience with boxer engines is limited, so i can't speak to that- but my engines all held up with solid compression, very minimal wear, and ran well the entire time i was using RP over hundreds of thousands of cumulative KM.
Although with my FRS im using Subaru OEM Filters, and Subaru/Idemitsu 0w-20. Got a dozen filters for $7 each, and the subaru oil was 5.99 here, which is a lot cheaper then anything else i can find locally. Any of the approved oils should be fairly similar, its more important to be changing it regularly IMO.
Ravenlokk is offline   Reply With Quote
Old 11-08-2012, 08:52 PM   #12
acro
Drives: GT-86
Used it for years without issue
acro is offline   Reply With Quote
Old 11-09-2012, 01:37 AM   #13
zoomzoomers
This is on a tangent, but my crickets came back. I was in bumper to bumper traffic for over an hour. I'm starting to believe that the crickets have something to do with excess heat as I always seem to get it after a long drive in bumper to bumper traffic. Anyone else notice this too?
RP did a good job of getting rid of the crickets there for a good while.
Old 11-09-2012, 06:24 AM   #14
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
whats so bad with mobil 1? and which grade was it? my last car i beat day in and out with mobile 1 every 3k miles no problems over 150k miles on the clock with the car being 13 years old (70k miles was put on the car in the last 2 year of its ownership with me) I also beat on it when it was cold, zero issues....
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
Royal Purple Synthetic Motor Oil 0w20 for the FR-S/BRZ at Redline360 Redline360 Engine, Exhaust, Bolt-Ons 5 12-29-2012 04:25 PM
Oil Change - Perhaps Royal Purple? RowTarEEE Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 47 11-01-2012 05:47 PM
For sale: New in box Royal Purple oil filter (model #10-2876) zoomzoomers Miscellaneous 0 10-30-2012 03:25 PM
Purple/White DRL OjiGeorge Cosmetic Modification (Interior/Exterior/Lighting) 5 09-13-2012 10:16 PM
Royal Purple Synthetic Motor Oil 0w20 for the FR-S/BRZ at Redline360 Redline360 Engine, Exhaust, Bolt-Ons 3 07-08-2012 01:04 PM
