Royal Purple for Manual Transmission
Anyone running Royal Purple 75w90 Maxgear in there manual transmission. Just wondering if anyone has had issues with this brand.
Thanks. |
Drives: 2015 BRZ, 2005 STI, 2024 Type R
Drives: Man
Thanks. I actually run Valvoline Synthetic 0w20 in my car. I was wondering what everyone was using in there transmissions. I see most run Redline or Mogul. Just Wondering if anyone is running royal purple maxgear and how good the quality was.
Thanks. |
Drives: 2013 BRZ (gone) 2016 Ford Fusion SE
I ran Motul 300 in my last transmission. Shifted smoothly once the car got warm. Didn't get rid of the odd rattle though, I needed a new tranny to fix that.
#7 | |
Thanks for the information. My FRS had 17400 when I picked it up and now has just shy of 18500 miles and I'm looking to replace both the diff and transmission fluids(no idea what the previous owner did to it). I've used Royal Purple in my manual transmission in my last car, 09' corolla xrs with no issues so Im thinking of giving it a try in my new car. |
Drives: 2015 Series.Blue
RP is a GL5, factory fill is a GL3/4
Why are you changing the fluid anyway? |
Drives: 2015 Crystal White BRZ Limited
#10 | |
There's a large difference between GL4 and GL5. Mainly that GL5 is designed for hypoid gears and contains friction modifier for limited slip differentials. This additive pack historically doesn't like to play well with Aisin transmissions as a general rule, causing hard shifting because the syncro isn't allowed to work correctly. GL fluids don't supersede, no matter how hard the dealer tells you otherwise... |
| Any Issues with Royal Purple? | akuhei | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 46 | 08-03-2015 04:06 PM |
| If I use royal purple oil will it void warranty? | brzadrian | Issues | Warranty | Recalls / TSB | 13 | 03-04-2014 01:59 PM |
| FS: Royal Purple API-licensed SAE 0W-20 Synthetic Motor Oil | Sportsguy83 | Mechanical Maintenance and Tools | 7 | 12-21-2012 08:10 PM |
| Royal Purple Oil - Possible GB (Vic Only) | fuddbutter | Australia Classifieds | 0 | 11-14-2012 07:48 PM |
| Oil Change - Perhaps Royal Purple? | RowTarEEE | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 47 | 11-01-2012 05:47 PM |
