Old 06-01-2013, 04:35 PM   #1
Meanderchap
Drives: Scion FR-S Whiteout 6MT
Do I need to use a torque wrench when installing Grimmspeed front license kit?
Hi all,
I'm a newbie in regards to any modification. I just received the Grimmspeed front license plate relocation kit, and in the instructions it states: Apply grease or anti seize to tow hook bolt. Using a 17mm socket, tighten the bolt to approximately 45 ft. lbs.
I was wondering, as I do not own a torque wrench, could I get away with using a regular socket wrench? Thanks!
Meanderchap is offline   Reply With Quote
Old 06-01-2013, 06:43 PM   #2
alex_86
alex_86's Avatar
Drives: 2013 scion firestorm frs
yes you can use a regular socket and ratchet. just don't over tighten it , you will be able to feel when it's tight.
alex_86 is offline   Reply With Quote
Old 06-01-2013, 06:50 PM   #3
Justin.b
Drives: 13 Hot Lava, 01 Miata, 09 Outback
You should probably pick up a torque wrench. It will come in handy when changing / rotating your tires as well. They're pretty cheap at Harbor Freight.
You can certainly do it without, but be careful not to over-tighten it because one of the kits (can't remember if it's the grimmspeed) uses an aluminum bolt and you can shear it off if you over-tighten it. You could shear off a steel one as well if you went to town on it, but obviously it's easier to do with aluminum.
-Justin
Justin.b is offline   Reply With Quote
Old 06-01-2013, 07:09 PM   #4
TemeCal
Drives: 86
I've never used a torque wrench on mine, but I agree with Justin.b though. Get yourself a cheapie torque wrench. You'll eventually need it for other things. Harbor Freight has one for $9.99 right now. If you're in the LA area, there should be several Harbor Freights nearby you.
http://www.harborfreight.com/1-2-hal...D%0AOCJ9%0D%0A
Use Coupon Code: 36633566
TemeCal is offline   Reply With Quote
Torque Wrench options FRiSson Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 17 03-14-2013 02:29 PM
Torque wrench... Vendors welcome Freeman Off-Topic Lounge [WARNING: NO POLITICS] 8 01-23-2013 05:30 AM
Digital Torque Wrench - Holiday Special blmw Exterior Parts - The Rest 6 01-14-2013 08:40 PM
Digital Torque Wrench - Member Special blmw Wheels and Tires 3 07-23-2012 12:18 PM
Which type of torque wrench do you prefer? Hanakuso Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 07-11-2012 04:17 AM
