Old 05-20-2016, 01:00 AM   #1
bass_114
bass_114's Avatar
Drives: wrb brz
Brembo swap, uneven pad contact
hey guys wondering if anyone can shine some light on this. Completed the full brembo sti swap and now have uneven pad contact on the disks. wondering why this is happening. I am referring to the rust forming on the outer edge of the rotor.
note the callipers were fully rebuilt.
Driver front:
Passenger front:
bass_114 is offline   Reply With Quote
Old 05-20-2016, 10:45 AM   #2
frslee
Just drive it
Drives: 13' FR-S
The pad is not fully covering the disc surface. No big deal.
frslee is offline   Reply With Quote
Old 05-20-2016, 12:52 PM   #3
bass_114
bass_114's Avatar
Drives: wrb brz
can it be adjusted in any way? cause all the parts are the right ones for fitment and weird that its not the same on passenger side vs driver
Old 05-20-2016, 02:50 PM   #4
churchx
churchx's Avatar
Drives: 2014 GT86
I wonder why do you care about it as much, if you did it mostly for looks, not performance/braking reliability?
The Following User Says Thank You to churchx For This Useful Post:
Mr.ac (05-20-2016)
Old 05-20-2016, 03:01 PM   #5
bass_114
bass_114's Avatar
Drives: wrb brz
lol you got me there, but for looks the rust that will eventually build up won't be appealing :0
Old 05-20-2016, 03:29 PM   #6
Toyarzee
Shibby!
Toyarzee's Avatar
Drives: '14 White FR-S, '01 turbo mini taco
Stock brake pads did not cover 100% of rotor surface either.
Either use them brembos and heat up those rotors, or clean them occasionally with brake cleaner and wire brush....
Or get over it lol
Toyarzee is offline   Reply With Quote
The Following User Says Thank You to Toyarzee For This Useful Post:
bass_114 (05-20-2016)
Old 05-20-2016, 07:14 PM   #7
atlbrz
Drives: Hyper Blue BRZ
Do the calipers have any kind of height adjustment? I had some Wilwoods and you had to set the height of the caliper using washers to set the height. You also had to be sure they were centered or you would get uneven pad wear.
atlbrz is offline   Reply With Quote
The Following User Says Thank You to atlbrz For This Useful Post:
Old 05-20-2016, 07:42 PM   #8
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Just soak your brake rotors in wd40 so they won't rust.
I'M JOKING DO NOT DO THAT.
But really it shouldn't matter as long as your brakes work. That's all that matters.
The Following User Says Thank You to Mr.ac For This Useful Post:
Old 05-20-2016, 08:05 PM   #9
bass_114
bass_114's Avatar
Drives: wrb brz
Thanks guys, im just saying since its not the same pad contact on the passenger vs driver side it seemed like we did soemthing wrong during the install
Old 05-20-2016, 08:38 PM   #10
zkv476
zkv476's Avatar
Drives: 2014 SWP BRZ, MT
Did you use new pads and rotors? Also what pad is it?
zkv476 is offline   Reply With Quote
Old 05-20-2016, 08:56 PM   #11
greg.bowring
Drives:
I'm experiencing similar. I reckon it's just new pads/rotors
greg.bowring is offline   Reply With Quote
Old 05-20-2016, 09:57 PM   #12
bass_114
bass_114's Avatar
Drives: wrb brz
Glad i'm not the only one, yup all new centric premium pads and disks
Old 05-20-2016, 09:59 PM   #13
Brake pads can be rusty before they even leave the factory if they are not speced to have inhibitor. The ones with inhibitor last a little longer. Those areas that don't rust (the noncontact areas) are usualy treated with a zinc coating. I see about 2 million rotors a year.
Old 05-21-2016, 05:03 AM   #14
Mr.ac
Mr.ac's Avatar
Drives: BRZ Premium
Not really, but it could be the brake shims that are moved more than the other side, thats my best guess. Or the mounting bolts are just a tad bit loose on one side making the whole caliper slide down just a hair.
STI Brembo bleeder swap suggestions??? Front calipers. Hachiroku14 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 58 01-24-2022 04:24 PM
Uneven Caster smg1138 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 05-03-2016 11:12 AM
Uneven drop on springs - why? JDM4E Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 09-14-2015 12:27 PM
uneven exhaust sweetfrs Engine, Exhaust, Transmission 27 04-24-2014 11:02 PM
Uneven steering assistance? koevasi Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 01-14-2014 09:06 AM
