Old 12-06-2013, 08:13 AM   #1
Hachiroku14
Drives: 2014 BRZ World Rally Blue
Question STI Brembo bleeder swap suggestions??? Front calipers.
I recently got this from a forum member and was gonna flip the bleeders for proper orientation for the twins. Stock bleeders came out with no problem. When i tried to take out the opposite side (allen screw), it just won't budge. Used a T40 torx bit but to no avail. So here's my dilemma...
should I:
a. Try to use a mini torch to heat up the screw and see if it will work? (possibly damaging the nice paint and risking the screw from breaking)
b. Just leave it like that and just reverse the whole caliper during install. (meaning the LEFT with install on the RIGHT). I read somewhere here that this doesn't affect performance. Although may lead to uneven wear of pads.
c. Leave it like that, separate caliper from rotor and just use a block of wood when bleeding while bleeder is pointing up.
Thanks!!!!
Hachiroku14 is offline   Reply With Quote
Old 12-06-2013, 08:27 AM   #2
infinite012
Drives: 13 DGM BRZ Ltd
Unfortunately, in order to break free bolts that were installed using Loctite (or other thread locker), you'll need to apply a considerable amount of heat. You could maybe get away with using a higher powered soldering iron and use just the tip (that's what she said) to heat the bolt in question. I think someone had mentioned using this method for their Brembos and it worked, but I don't want to spend any time searching for that since that's something you could do.
infinite012 is offline   Reply With Quote
Old 12-06-2013, 09:14 AM   #3
Vten
Drives: Too heavy
depends on how old the calipers are. the older the caliper the harder to get those allen nuts out. mine was 07s, and I used the torch to take those allen bolts out, but left the browning residue due to the heat. It wasn't a big deal for me since I was planning on powdercoat the caliper anyway.
a friend of mine suggested to not bother with it and told me to just separate the caliper to bleed the fluid but I don't think it's practical.
Vten is offline   Reply With Quote
Old 12-06-2013, 10:47 AM   #4
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Torch. Those are differential bored calipers, so use them correctly.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 12-06-2013, 02:46 PM   #5
empower-auto
Kouki-Monster
empower-auto's Avatar
Are these the calipers that are direct fit with the bleeders flipped? What year are they from ?
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
Old 12-06-2013, 02:50 PM   #6
OrbitalEllipses
Drives: Attitude
04-07 STI. With bleeders flipped they are oriented correctly as they are differentially bored - the leading and trailing pistons are different sizes.
Old 12-06-2013, 02:53 PM   #7
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I swapped the bleeders on my 2008-2012 STI calipers, and I don't recall it being a torx bit, it was just a standard metric allen bit. I used a 3/8" breaker and my allen bit socket and had no issue removing them and swapping them after I bolted the calipers to the car. My advice would be to use some heat but possibly try and take some measures to protect the paint on the caliper.
Old 12-06-2013, 02:55 PM   #8
King Tut
NASA SpecE30 Racer
King Tut's Avatar
As Obital mentioned these are the cheap from Japan gold 04-07 STI calipers. The newer black 08-12 STI front calipers are the same and also bolt on but need the bleeders flipped as well.
Old 12-06-2013, 02:58 PM   #9
OrbitalEllipses
Drives: Attitude
It's pretty easy to shear the threads in the caliper because aluminum. I *highly* recommend heat.
Qué? Available on USDM 04-07 STI. Available on JDM/UKDM 01+ STI.
Old 12-06-2013, 03:06 PM   #10
No Limit Motorsport
No Limit Motorsport's Avatar
Drives: 2013 DGM BRZ
Send a message via AIM to No Limit Motorsport
I had to drill the allen heads out, and re-tap the threads. Mine wouldn't come out with no matter how much heat and PB blaster I applied.
Take the time and do it right.
No Limit Motorsport is offline   Reply With Quote
Old 12-06-2013, 03:15 PM   #11
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Most of these you see come from Japanese breaker yards and they are relatively cheaply found on eBay. They normally display damage to the paint as well. I am not implying they are any better or worse than the newer ones just easier and cheaper to find.
Old 12-30-2013, 02:54 PM   #12
Figo
Figo's Avatar
Drives: Vortech Supercharged FR-S
When you guys say swap bleeders, do you mean do it like this (please see attachment)? Only the front need it right?
I just got a set of 08 sti caliper front and rear, and I am thinking to swap bleeder before powder coating them.
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me.
Your car is your story, so don't let someone else write the book.
( White Tiger ) - FiGo's 車誌.
Figo is offline   Reply With Quote
Old 12-30-2013, 03:19 PM   #13
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Yes. Fronts only.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 12-30-2013, 03:20 PM   #14
OrbitalEllipses
Drives: Attitude
Yes. Fronts only.
^Yes.
Custom BBK using Project Mu parts and EvoX brembo calipers jadewbj Suspension | Chassis | Brakes -- Sponsored by 949 Racing 26 04-03-2014 05:15 PM
Complete Brembo Front BBK packages! Starting at $881 delivered!!! Infamous Performance Brakes, Suspension, Chassis 86 02-03-2014 09:40 PM
Green Brembo Brake Calipers, and Stock Springs Sivtec Brakes, Suspension, Chassis 23 11-25-2013 10:20 AM
Good deal on brembo calipers or not? red1993sol Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 10-07-2013 02:26 AM
Noise from front calipers after pad/rotor install BRZranger Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 03-24-2013 12:48 PM
