Old 08-21-2015, 09:38 AM   #1
JDM4E
Drives: Honda Accord Euro
Uneven drop on springs - why?
Why manufactures, such as Eibach and others, make springs that drop the car uneven front and rear? For example EU Eibach pro kit is listed as -25mm front, -20 rear. Why?
My average joe brain would say, that you want the car even with the road as OEM (is it?).
JDM4E is offline   Reply With Quote
Old 08-21-2015, 09:52 AM   #2
Racecomp Engineering
Most of the time it's for looks....but you can use rake to your advantage if you know what you're doing. IMO for lowering springs the main reason for doing it is just looks (the wheel arch is bigger in the front).
- Andrew
The Following User Says Thank You to Racecomp Engineering For This Useful Post:
JDM4E (08-25-2015)
Old 08-21-2015, 09:58 AM   #3
JDM4E
Thanks, I had the same thought. So if I don't know what I am doing then finding springs that are even (or set coilovers evenly) is preferable, right?
Old 08-21-2015, 10:04 AM   #4
That's usually a good place to start and it will help you focus on other more important things (like alignment and tire pressures).
A good suspension tuner can help you out when it comes to looking at the full system.
- Andrew
Old 08-21-2015, 10:05 AM   #5
Doesn't hurt if you "don't know what you are doing" either it is just you won't see the handling advantage. It is marginal even for the guys that do know how to use it.
If doing for looks then the larger drop in front does have a bigger effect. As RCE said the wheel arch in the front is bigger so by dropping the front that tiny bit more it evens things out.
Old 08-21-2015, 10:10 AM   #6
- Andrew
This^^^ if it is performance and not looks that is your priority.
Old 08-21-2015, 03:41 PM   #7
Nigelr32
Drives: '14 GT86 project, '13 GT86 DD
It could also be the fact that the rear shocks are shorter so limiting the drop on them is less likely to cause them bump stopping all the time,( I think you call them jounce rubbers in the good ol USA)??
Nigelr32 is offline   Reply With Quote
Old 08-21-2015, 04:31 PM   #8
soulreapersteve
Contract? /人◕ ‿‿ ◕人\
soulreapersteve's Avatar
Bump stops also here in 'Murica. Never seen jounce rubbers being mentioned before, at least during my short time researching all things suspension.
The Twins make me smile
Old 08-21-2015, 04:37 PM   #9
DAEMANO
Time Traveller
Sometimes also referred to as Jounce Bumpers. Which actually may be a more accurate term depending on the usage.
The Following User Says Thank You to DAEMANO For This Useful Post:
soulreapersteve (08-21-2015)
Old 08-21-2015, 05:24 PM   #10
Nigelr32
Sorry guys. I used to own a 2008 Mustang GT, I bought shorter bump stops from Roush. They were called Jounce rubbers or bumpers.
Old 09-10-2015, 07:24 PM   #11
JDM4E
Well it seems harder than I thought to find 1" evenly dropped springs.
Thinking about Pro Kit and live with the 25/20mm drop, but my OCD would love to know what effect the "rake" has on a car? I tried google it but without much success.
Old 09-12-2015, 08:20 AM   #12
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
It has no real effect besides look.
Old 09-12-2015, 12:14 PM   #13
There is an effect, but 5mm isn't a lot of rake. Generally, a rear higher than the front will promote a little more oversteer...however too low in the front will result in riding on the bumpstops which causes understeer. Depending on how much rear travel you have and how ride height is adjusted, a taller rear (with more bump travel) will help you put power down exiting a corner.
Our RCE Yellow springs are an even 20mm drop.
- Andrew
JDM4E (10-03-2016)
Old 09-12-2015, 12:33 PM   #14
wparsons
wparsons's Avatar
They also use less shock travel for the same wheel travel than the fronts.
flickr
Drop Knuckles instead of lowering Springs or Coilovers FRSPacNW DIY (Do-It-Yourself) Guides 19 10-09-2017 12:42 AM
Smaller Springs for more Drop? 636 Cosmetic Modification (Interior/Exterior/Lighting) 1 08-03-2015 09:28 AM
Who has H&R Super Sport Springs? How much did they actually drop your car and how do NickFRS Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 02-25-2013 11:06 PM
Dealer Option 30mm Drop Lowering Springs switchlanez Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 09-12-2012 04:50 PM
Drop Springs rather than Coil Overs??? Kuneff Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 08-31-2012 10:16 AM
