Old 05-12-2016, 08:53 PM   #1
kam628
Drives: 2014 Subaru BRZ
DIY: hard wiring gauges, radar, etc to ignition
If anyone is wondering where a power source is when you turn the ignition on, to power up gauges, radar, etc. If you take the cover around steering wheel off. The connector that goes into the wiper switch. Use the brown and striped white wire. The black wire is ground. I didnt want to get add a fuse wire to fuse panel. Trying to keep everything clean. Hope this helps someone out.
kam628 is offline   Reply With Quote
Old 05-12-2016, 09:51 PM   #2
ryoma
ryoma's Avatar
I personally think that everyone should use an "add a fuse" method when adding switched power to anything. I am not a fan of splicing OEM wires for power because it is not reversible
The Following User Says Thank You to ryoma For This Useful Post:
XanRules (05-13-2016)
Old 05-12-2016, 09:57 PM   #3
kam628
I didn't splice anything. I used that connector that puts 2 wires together. I do understand what your are saying it's just cleaner in my opinion.
Old 05-12-2016, 10:41 PM   #4
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
A wire tap I'm guessing? Those still cut through the insulation in the wire to make contact with the actual conductor in the wire. So its kindaa reversible, just wrap the contact area with electrical tape afterwards if you remove the tap.
I agree though, using add-a-fuse is better. I just wish there was a good way to keep the fuse box cover attached.
PandaSPUR is offline   Reply With Quote
Dash Cam Hard Wiring Alternative steeloyangster Scion FR-S / Toyota 86 GT86 General Forum 24 02-02-2016 03:20 PM
Questions Related to Hard-wiring Dashcam carma143 Electronics | Audio | NAV | Infotainment 2 09-09-2015 06:26 AM
Harding wiring radar detector speedy racer Cosmetic Modification (Interior/Exterior/Lighting) 9 10-03-2013 06:00 PM
Radar L3P47 Electronics | Audio | NAV | Infotainment 31 05-15-2013 01:53 PM
radar detectors Touge_ninja Off-Topic Lounge [WARNING: NO POLITICS] 9 02-24-2013 03:27 PM
