Old 05-11-2016, 07:06 PM   #1
slow15frs
slow15frs's Avatar
Drives: 15 scion frs
stock tune only bolt ons dyno
just got my car dyno'd today at efi logics and kinda surprised with my numbers 188 and 158 with front pipe back and perrin intake
youtube vid
[ame="https://www.youtube.com/watch?v=UJwQvq09lq0"]2015 frs dyno stock tune bolt ons efi logics - YouTube[/ame]
2015 Scion FR-S-hot lava 6MT Perrin cai magnaflow cbe EFI LOGICS tuned 193whp
slow15frs is offline   Reply With Quote
Old 05-11-2016, 07:08 PM   #2
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
What was the stock baseline?
Freeman is offline   Reply With Quote
Old 05-11-2016, 07:09 PM   #3
slow15frs
slow15frs's Avatar
Sent from my SM-G935P using Tapatalk
Old 05-11-2016, 07:16 PM   #4
jaorocks1
jaorocks1's Avatar
Drives: 92 Prelude
It's all been a lie....
jaorocks1 is offline   Reply With Quote
Old 05-11-2016, 08:13 PM   #5
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
??? I'm pretty confused whats the lie here?
Old 05-11-2016, 09:24 PM   #6
MrDinkleman
Drives: 2016 Oceanic, "base" model
I think that "bolt ons won't give you any measurable gains".
MrDinkleman is offline   Reply With Quote
Old 05-11-2016, 09:47 PM   #7
slow15frs
slow15frs's Avatar
so then explain my power bump
Old 05-11-2016, 10:20 PM   #8
ryoma
ryoma's Avatar
I have never heard the myth that bolts on don't give a power bump for our car. if you get headers with a tune, it will definitely give you a power bump. same with some intakes as well. however, don't expect to get over 200whp with bolt ons unless you go e85
Old 05-11-2016, 10:24 PM   #9
humfrz
That's an impressive gain.
So, is your car's header stock .. ??
Stock tune ..right ..... ??
Running on mostly gasoline .. ??
humfrz
PS - next time you may consider posting a shot of the dyno screen/printout .....
Old 05-11-2016, 10:31 PM   #10
slow15frs
slow15frs's Avatar
Oe header stock tune on 93 pump
Ill post the dyno sheet tomorrow
Old 05-11-2016, 10:49 PM   #11
jaorocks1
jaorocks1's Avatar
Drives: 92 Prelude
Are you running lean? Check your AFR.
Old 05-11-2016, 11:00 PM   #12
slow15frs
slow15frs's Avatar
Stock tune is very rich
Old 05-12-2016, 12:13 AM   #13
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Intakes can effect AFR which is why he asked Im pretty sure. Intake runs lean adding HP but not as safe.
IDK if the Perrin does but thats a big power bump on stock tune. Did you do more then 3 runs and was the 165 you car or just another car on the same dyno
and would be interested to see the actual plot to see the whole powerband and whats gained under the curve vs peak numbers
Old 05-12-2016, 12:18 AM   #14
FRSBRZGT86FAN
Ace header has hit 200 whp in some cases
Tune w/bolt ons derekk Scion FR-S / Toyota 86 GT86 General Forum 16 06-19-2014 02:50 PM
A/T, AVO panel filter, Borla UEL, Stock cat-back, Drift Office dyno tune Turbo Den Engine, Exhaust, Transmission 2 09-20-2013 02:01 AM
Visconti vs FA20Club vs Stock Tune Dyno Results mechaghost Engine, Exhaust, Transmission 153 07-08-2013 11:35 AM
Moar power with simple bolt-ons & ECUTek tune @ OnPoint Dyno l8apexr CANADA 23 04-25-2013 06:50 AM
Bolt ons+Tune Obja Engine, Exhaust, Transmission 16 04-24-2013 10:04 AM
