Old 09-19-2013, 06:36 PM   #1
Turbo Den
Drives: FRS, IS300, 911sc
A/T, AVO panel filter, Borla UEL, Stock cat-back, Drift Office dyno tune
Sharing my results with Drift Office dyno tune.
the base line is AVO panel, Borla UEL, J2 HFC, stock cat-back.
http://www.flickr.com/photos/102318852@N02/9823679006/
I am impressed with the result, and MORE impressed after trying the Map #2 which is more aggressive. Ideally, I want no torque dip at all. But the tune already shortened the dip from 1800rpm range (3,200 to 4,500rpm) to about 500rpm between 3200 to 3800rpm.
I have tried many different setup...
1) K&N panel + magnaflow catback ... too loud, only high rpm gains.
2) Injen intake + catless front pipe + stock catback... sounds good, noticeable gains.
3) Injen intake + Borla UEL + HFC + stock catback.... felt the same as above.
4) stock intake with AVO panel, Borla UEL + HFC + stock catback
5) above + Drift Office tune... minimized torque dip and maximized benefits from other mods.
If I would do it over again... I would jump right into Borla UEL + Drift Office tune.
Bob, if you are reading this, if you find a way to increase even more low-mid range torque, even at sacrifices of high rpm power... I will be first to visit you again.
Turbo Den is offline   Reply With Quote
Old 09-19-2013, 09:48 PM   #2
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
what is a J2 HFC? is that an exhaust piece? thx
Boofneenee is offline   Reply With Quote
Old 09-20-2013, 02:01 AM   #3
Turbo Den
J2 high flow cat front pipe sold by Jon Motoring.
Drift Office Tune vs Visconti Tune mechaghost Engine, Exhaust, Transmission 109 07-03-2014 12:57 AM
Drift-Office : Borla UEL Header... TUNED. Drift-Office Engine, Exhaust, Transmission 41 10-26-2013 11:54 AM
Drift-Office N/A tune zuldajin Engine, Exhaust, Transmission 14 07-09-2013 08:38 PM
T1R Full Exhaust re-dyno x DRIFT OFFICE TUNE !!!! AJ PwR Engine, Exhaust, Transmission 19 04-25-2013 05:10 PM
Drift-Office Stage 1, 92 Oct tune BRZranger Engine, Exhaust, Transmission 15 01-07-2013 09:40 PM
