Drives: car
Ignition system explaination?
I'm wondering, do GT-86's have a traditional ignition system? That is, ignition coils and distributor? I am clueless about this.
...Just add nauseum
Drives: 2003 (AP1) S2000
No distributor.
4 ignition coils, 1 mounted directly on each individual spark plug. Each ignition event is controlled by the ECU. There is an ignition map (fancy word for a table) that the ecu uses to determine when, relative to top dead center, the spark will happen. The variables are rpm and engine load, in grams of air, by mass, ingested per rev. There are supplemental tables which modify the ignition timing for knock compensation and cold starting, among other things.
There are many ways to displace.
-Spartarus |
#3 | |
DANG @radroach ....you got some catching up to do ....... ![]() humfrz |
Drives: 2014 BRZ SCCA STU endurance car
And just a heads up radroach, if anyone tries to sell you spark plug wires to improve the performance, run away and never go back to them. Every now and then we get customers saying that so and so said they should do performance mods on systems the car doesn't even have.
#5 | |
Drives: Full race 4cyl boxer
Like the "audiophile quality" $10,000 Ethernet cables that are "directional"? http://arstechnica.com/staff/2015/02...y-makes-sense/ In all fairness - not all sparkplug wires are made equal. If you use the wrong wires with a MSD CD ignition, I have heard that it will fry the MSD electronics. |
| BRZ keyless entry/ignition and auto climte control system how-to video | ayau | BRZ Photos, Videos, Wallpapers, Gallery Forum | 26 | 11-21-2013 01:58 AM |
| Simple explaination of HP vs Torque, using an FRS as an example.. | BRZnut | Scion FR-S / Toyota 86 GT86 General Forum | 37 | 03-08-2013 02:24 AM |
| Aftermarket Push Button Ignition Smart Entry System | zAnSh1n | Electronics | Audio | NAV | Infotainment | 75 | 08-19-2012 02:23 PM |
