Old 03-03-2013, 02:28 PM   #1
BRZnut
Drives: BRZ DGM Limited
Simple explaination of HP vs Torque, using an FRS as an example..
Video near the end uses the FRS as an example of a car with a dip in torque mid-RPM, making the car feel "gutless". I know others have noticed this but I haven't. Will need to pay attention more.
http://cnettv.cnet.com/car-tech-101-...-50141789.html
The Following 11 Users Say Thank You to BRZnut For This Useful Post:
6-Shift (03-03-2013), akuhei (03-03-2013), Black Tire (03-05-2013), Bristecom (03-05-2013), Ericc B (03-05-2013), Guff (03-04-2013), JETRED (03-03-2013), Mandy (03-04-2013), Panda Grahams (03-04-2013), Poogles (03-04-2013), russv (03-03-2013)
Old 03-03-2013, 08:35 PM   #2
Snozzberries
Drives: FR-S Whiteout
I definitely notice the torque dip depending on my clutch play. If I am driving super easy, I don't usually see it. If I am dumping at 3k, I don't usually see it.
Snozzberries is offline   Reply With Quote
Old 03-03-2013, 08:37 PM   #3
SloS13
Drives: 2013 FR-S whiteout
Horsepower - how fast you hit the wall. Torque is how far you take the wall with you.
SloS13 is offline   Reply With Quote
The Following 4 Users Say Thank You to SloS13 For This Useful Post:
Anthonytpt (03-03-2013), Craig (03-04-2013), jwbrocloud (03-04-2013), russv (03-03-2013)
Old 03-03-2013, 10:08 PM   #4
BRZnut
It shows the Torque takes a dump at 4K RPM. I'll have to see if I notice it
Old 03-03-2013, 10:13 PM   #5
akuhei
akuhei's Avatar
Drives: Raven M/T FR-S
I definitely notice...its like the car slows between 3.5-4.5k wish..before picking back up and pulling again. The tune helped..but its still there and bothers me a little...
Akuhei's Blog
"Inconceivable"
akuhei is offline   Reply With Quote
Old 03-03-2013, 10:20 PM   #6
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
Nothing new as far as a NA 4 cylinder. You drive it with the engine over 5000 RPM if you want results.
I personally love that early torque, works well in town.
Rayme is offline   Reply With Quote
Old 03-03-2013, 10:41 PM   #7
BRZnut
Have to agree..the early torque adds a great deal of pep around town.
Old 03-03-2013, 10:55 PM   #8
fatoni
calm down, this is the internet. we wont have your sense here. we want to drive a slow car slowly and complain about how it not being fast.
The Following 3 Users Say Thank You to fatoni For This Useful Post:
CaptainSlow (03-05-2013), Rayme (03-04-2013), WatchmaN (03-05-2013)
Old 03-03-2013, 11:35 PM   #9
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
Yeah, that's the way to look at it. People tend to complain about the torque dip when we should instead be grateful for the 2 peaks gifted to us.
The Following User Says Thank You to switchlanez For This Useful Post:
R2RO (03-04-2013)
Old 03-04-2013, 01:07 AM   #10
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
While accurate, it was too fast and poorly presented. He glanced over the most important difference between the two in a matter of seconds.
PRO86 | WTCC | STL
Old 03-04-2013, 01:35 AM   #11
dnL
Drives: Ultramarine FR-S
I only watched the vid because an FR-S is in it.
dnL is offline   Reply With Quote
Old 03-04-2013, 02:47 AM   #12
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
After all... who dosen't like 2 peaks
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Old 03-04-2013, 04:27 AM   #13
switchlanez
I can try to explain the horsepower/torque relation using basic terms and equations.
Torque can be described in ft-lbs (as we know it). It's the rotational force (in lbs) applied across a 1 foot lever arm. So if you're torquing down a bolt and apply 1 lb of weight on the stub end of a footlong wrench that equals 1 ft-lb of torque.
Power equation is:
Where
P(t) = Power(as a function of time) in watts. Can be converted to horsepower by multiplying by a conversion factor. Either way, watts and horsepower describe a unit of power. The "function of time" part means there is a unit of time on the right side of the equation (in the "w").
T (Greek symbol for Tau) = Torque in the unit of Newton-meters. Can be converted to foot-pounds using a conversion factor. Either way, N-m and ft-lbs describe a unit of torque.
w (Greek symbol for omega) = angular velocity in radians (# of circles of rotation) per second. Can be converted to frequency in rpm using a conversion factor. Either way, angular velocity and rpm describe units of rotation over time making the Power equation a function of time (as mentioned earlier).
Essentially, horsepower is torque multiplied by rpm. But the equation above assumes everything is in metric units (watts, N-m, rad/sec) so we have to convert everything to English units (horsepower, ft-lbs, rpm). That horsepower to torque relationwith all metric-English conversion factors lumped in becomes:
(f = frequency in rpm which is the analog of angular velocity [w] in units in the first equation)
TL;DR: hp = torque x rpm / 5252
The Following 2 Users Say Thank You to switchlanez For This Useful Post:
cfusionpm (03-04-2013), Sigh-on-Rice (03-04-2013)
Old 03-04-2013, 08:47 AM   #14
ZDan
ZDan's Avatar
Drives: '23 BRZ
Power equation is:
If power is a function of time, then so must be either torque and/or rpm.
If torque and engine rotational speed are constant, not varying with time, then power P = T*w (should be a tau and an omega there, but no greek symbol font available!), torque multiplied by angular rotation speed, not a function of time.
You could have an expression for power varying over time shown as P(t), but then you would have an equation in terms of time "t".
Saying P(t) = T*w doesn't make sense, as there's no "t" in there, and if T and w are fixed, so is P.
Simple Oil Temp. Gauge Sportsguy83 Cosmetic Modification (Interior/Exterior/Lighting) 4 01-19-2013 08:25 PM
A not so simple question. Asterisked Accolade Tracking / Autocross / HPDE / Drifting 10 01-18-2013 08:40 PM
Simple blinker mod, nice look Carban Cosmetic Modification (Interior/Exterior/Lighting) 7 09-29-2012 08:09 PM
Simple Question! Spencer Strayer Scion FR-S / Toyota 86 GT86 General Forum 0 09-09-2012 06:53 PM
simple tires? jarviz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 08-02-2012 03:43 PM
