Old 05-08-2016, 10:55 PM   #1
radroach
Drives: car
Ignition system explaination?
I'm wondering, do GT-86's have a traditional ignition system? That is, ignition coils and distributor? I am clueless about this.
Old 05-08-2016, 10:58 PM   #2
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
No distributor.
4 ignition coils, 1 mounted directly on each individual spark plug. Each ignition event is controlled by the ECU.
There is an ignition map (fancy word for a table) that the ecu uses to determine when, relative to top dead center, the spark will happen.
The variables are rpm and engine load, in grams of air, by mass, ingested per rev.
There are supplemental tables which modify the ignition timing for knock compensation and cold starting, among other things.
There are many ways to displace.
-Spartarus
Spartarus is offline   Reply With Quote
The Following 5 Users Say Thank You to Spartarus For This Useful Post:
COO86L (05-09-2016), DustinS (05-09-2016), eddieflyinv (05-09-2016), humfrz (05-09-2016), radroach (05-09-2016)
Old 05-09-2016, 03:54 PM   #3
Originally Posted by Spartarus View Post
No distributor.
That was a nice response ........
DANG @radroach ....you got some catching up to do .......
eddieflyinv (05-09-2016), radroach (05-09-2016)
Old 05-09-2016, 06:37 PM   #4
Gear_One_Performance
Gear_One_Performance's Avatar
Drives: 2014 BRZ SCCA STU endurance car
And just a heads up radroach, if anyone tries to sell you spark plug wires to improve the performance, run away and never go back to them. Every now and then we get customers saying that so and so said they should do performance mods on systems the car doesn't even have.
Gear_One_Performance is offline   Reply With Quote
The Following User Says Thank You to Gear_One_Performance For This Useful Post:
justatroll (05-09-2016)
Old 05-09-2016, 07:03 PM   #5
justatroll
justatroll's Avatar
Drives: Full race 4cyl boxer
Like the "audiophile quality" $10,000 Ethernet cables that are "directional"?
http://arstechnica.com/staff/2015/02...y-makes-sense/
In all fairness - not all sparkplug wires are made equal.
If you use the wrong wires with a MSD CD ignition, I have heard that it will fry the MSD electronics.
justatroll is offline   Reply With Quote
BRZ keyless entry/ignition and auto climte control system how-to video ayau BRZ Photos, Videos, Wallpapers, Gallery Forum 26 11-21-2013 02:58 AM
Simple explaination of HP vs Torque, using an FRS as an example.. BRZnut Scion FR-S / Toyota 86 GT86 General Forum 37 03-08-2013 03:24 AM
Aftermarket Push Button Ignition Smart Entry System zAnSh1n Electronics | Audio | NAV | Infotainment 75 08-19-2012 03:23 PM
