Old 05-02-2016, 07:52 PM   #1
Ardenyo2k13
Drives: scion frs
how to disable drl ?
how do u guys disable your drl someone help thnx
Ardenyo2k13 is offline   Reply With Quote
Old 05-02-2016, 07:59 PM   #2
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
There are 2 possible ways which are the safest and doesn't involve touching wiring:
1) Get a techstream cable and use this to install techstream:
http://www.ft86club.com/forums/showthread.php?t=73034
Use techstream to disable the DRL around $20 for a good techstream cable
2) My favorite as I've done this beta for awhile:
Get a $5 bluetooth OBD-II dongle and download an pay $20 for the app carista on the itunes or play store and use it to disable the DRLs. You can also use that same bluetooth obd 2 dongle for another app called torque which is awesome and can be used for real time displays and logging.
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
Teseo (05-02-2016)
Old 05-02-2016, 08:00 PM   #3
Jaden
Road-hole
Drives: 2013 Whiteout FR-S
you can do it with a tactrix...
You use a tactrix and the techstream software...
Jaden
Jaden is offline   Reply With Quote
Old 05-02-2016, 08:09 PM   #4
roddy
roddy's Avatar
Drives: '13 Ultramarine
There is also this option...
http://www.ft86club.com/forums/showthread.php?t=7435
Old 05-02-2016, 09:16 PM   #5
humfrz
I give up ....... why would anyone want to disable the DRLs .......??
humfrz
chaoskaze (05-02-2016), stevesnj (05-02-2016)
Old 05-02-2016, 09:24 PM   #6
sgtcarrot
Drives: Scion FR-S 2015 Blue and stock
Random thought: I seem to recall when I was reading the car manual from cover to cover that this is an ECU setting that you can have the dealer set for you. They can turn off DRL, set timing for auto lock, how long the lights stay on after lock, whether it beeps or not when you remote lock, and a couple of other options that were supposed to be set during initial delivery.
Or I may be imagining it, not sure, but thought I would throw this out there as I seem to recall that DRL was one of the options that the dealer could just change if you asked for it.
sgtcarrot is offline   Reply With Quote
Old 05-02-2016, 09:26 PM   #7
Pat.Thornton
Pat.Thornton's Avatar
Drives: 2014' 86
To answer humfrz:
I disabled them when had stock headlights because i don't like the look. I feel it makes the car look cheap. Since i bought winjet headlights though i have turned them back on
Pat.Thornton is offline   Reply With Quote
The Following 2 Users Say Thank You to Pat.Thornton For This Useful Post:
FRSBRZGT86FAN (05-03-2016), humfrz (05-02-2016)
Old 05-02-2016, 09:27 PM   #8
sgtcarrot
humfrz
My guess is because they dont look good.
Yes, I think DRL is a great idea and everybody should have them, there is literally no downside.
On the otherhand, I feel like ours look like they were borrowed off an older car. I dont love them, and would replace them with something else, but I would still have them either way.
The Following User Says Thank You to sgtcarrot For This Useful Post:
humfrz (05-02-2016)
Old 05-02-2016, 09:32 PM   #9
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
Because I want my fog lights to stand out during the day... Lmao
Nah I'm keeping mine.
Packofcrows is offline   Reply With Quote
The Following 2 Users Say Thank You to Packofcrows For This Useful Post:
MTpockets (05-02-2016), stevesnj (05-02-2016)
Old 05-02-2016, 09:35 PM   #10
FRSBRZGT86FAN
That's exactly right, that's what the carista app and techstream both change. You can even change on the FR-S how long to wait before it auto locks the doors after being unattended. Those aren't set at delivery/initialization they honestly are set at the factory default from the ecu. If you ask a mechanic at toyota to edit them they may just look blankly at you
sgtcarrot (05-03-2016)
Old 05-02-2016, 10:24 PM   #11
darthpnoy1984
Drives: 15 ZN6 Asphalt
Swap them out for Winjets you'll get the LED DRL which will standout alot more.
2015 ZN6 DD AT
darthpnoy1984 is offline   Reply With Quote
Old 05-02-2016, 10:26 PM   #12
stevesnj
stevesnj's Avatar
I put LED bulbs in at 6k temp and looks way better than the yellow halogens.
My 2016 Build thread
Old 05-02-2016, 10:50 PM   #13
humfrz
Thanks for responding to my question.
Well, now, folks ....... I usually try to keep an open mind to most things.
So, I went out and fired up my machine (MT) and the DRLs came on. I set the parking brake to get out to look at them and they went off.
I'm thinking that I never would (almost never) leave my car running in neutral and exit it, without setting the parking brake........ so, I would never see my machines DRLs, even if they were ugly.
So, I left my car running and got out and looked at the DRLs. I think they look pretty neat.
What a relief for me, now knowing, that I'm not driving around with ugly front lights, just for the sake of safety .......
humfrz - another slow day in Puyallup ......
The Following 9 Users Say Thank You to humfrz For This Useful Post:
bcj (05-02-2016), jawn (05-03-2016), joe strummer (05-03-2016), MTpockets (05-02-2016), sgtcarrot (05-03-2016), soulreapersteve (05-02-2016), strat61caster (05-03-2016), Tcoat (05-03-2016), Ultramaroon (05-03-2016)
Old 05-02-2016, 11:15 PM   #14
D5teph
Automotive Enthusiast
D5teph's Avatar
Drives: Zenki 86
What brand bulbs did you switch to? I'm looking to switch my stock ones out that's why.
D5teph is offline   Reply With Quote
The Following User Says Thank You to D5teph For This Useful Post:
stevesnj (05-03-2016)
How to disable the 120 kph warning - UAE captaindubai ASIA 25 05-21-2023 03:54 PM
How to disable DRL in FRS whitefrs Cosmetic Modification (Interior/Exterior/Lighting) 12 12-13-2016 02:11 PM
i want to disable the nannies soundman98 Electronics | Audio | NAV | Infotainment 9 02-23-2014 09:25 PM
Can any tuners disable TC/VDC? himbo Software Tuning 52 01-13-2014 10:12 PM
Is there a way to disable the immobilizer? schtebie Issues | Warranty | Recalls / TSB 5 09-22-2012 06:09 PM
