Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > ASIA
Old 12-02-2013, 09:05 PM   #1
captaindubai
Drives: 2012 GT86
How to disable the 120 kph warning - UAE
Just bought my GT86 and the 120 kph warning does not stop!
I don't mind being warned but mine just keeps going above 120 kph instead of stopping.
Anybody know how to turn it off completely or just have a couple of beeps as you pass 120 kph?
Thanks.
captaindubai is offline   Reply With Quote
Old 12-03-2013, 04:18 AM   #2
lgunnz
Drives: 2013 Toyota GT86
This has been posted a couple times and no one seems to have an answer. I spent a good amount of time googling it and came up with zip
2013 Asphalt GT86
HKS F-Con is: HKS V1 Supercharger: Tomei UEL Header: Tomei Overpipe: Trust/Greddy CS GTS Ver. 2 Exhaust: Airlift Suspension: Sard Seat Covers: Defi Boost Gauge: Innovate Wideband A/F Gauge: Ca-Fi Dashlinq4 Headunit: KM4SH #006: Tom's TN06 Wheels: Winjet Headlights: Tom's Tails: Beatsonic Shark Fin: Hood Struts
lgunnz is offline   Reply With Quote
Old 12-03-2013, 05:59 AM   #3
ZionsWrath
Thanks
ZionsWrath's Avatar
1. insert ipod
2. turn up volume
3. ???
4. profit
Old 12-03-2013, 06:59 AM   #4
Bahraini86
Bahraini86's Avatar
Drives: Toyota GT86
There's no programming for this. It must be removed physically via opening the lower dash. And normally dealers avoid doing that due to GCC traffic regulations
'73 240z Triple-Carbed '03 350z Supercharged (455whp) '09 135i Twin-Turbocharged (11.85@188km/hr)
Bahraini86 is offline   Reply With Quote
Old 12-03-2013, 10:27 PM   #5
captaindubai
Drives: 2012 GT86
I read somewhere that the dealer can re-programme the car to tell the ECU that it it in a different territory - i.e. Europe. And this will disable the beep altogether. Anybody confirm this?
Old 12-04-2013, 05:31 AM   #6
Bahraini86
Bahraini86's Avatar
Drives: Toyota GT86
spoke to the technician directly and he confirmed that ECU programming for this issue is still not available for our region
Old 12-04-2013, 06:40 AM   #7
RevoG
RevoG's Avatar
Drives: Hot Lava 86 MT
This is one of those projects that I want to sort out over this coming December. Will take my instrument cluster apart and remove the buzzer from it. This seems to be the only way to get this done.
Every American car I have all do the same: one ding and that's it. Not this annoying continues dinging.
JR Supercharger, JR RS Pulley, JR Oil cooler, JDL UEL header, Dual resonated 3" JDL Overpipe Front pipe, Perrin 3" resonated cat back exhaust, Upgraded Koyorad radiator, ECUTek tune, Enkei RS05RR 18x9.5, Bridgestone RE003 265/35/18, KW V3 Coilovers, Valenti sequential taillights, Kartboy short shifter kit
RevoG is offline   Reply With Quote
Old 12-04-2013, 09:58 PM   #8
captaindubai
Drives: 2012 GT86
I would be quite happy to pay you to do mine at the same time. Can you PM me so we can co-ordinate? Thanks.
Old 12-05-2013, 02:11 AM   #9
lgunnz
I think this needs a DIY. There's plenty of 86/BRZ owners in the region
2013 Asphalt GT86
Old 12-05-2013, 06:15 AM   #10
RevoG
RevoG's Avatar
I need to do the first one to see where the buzzer is and if it is a workable solution. I know it has been done on other Toyota's in the past. Just need the time to do it...
Old 12-05-2013, 07:04 AM   #11
Acid18
Acid18's Avatar
Drives: 2013 GT86 Lightning Red
i just need a ding on 120 and im fine with it? can you do mine?
Mods: VDS Headers, Milltek Header Back System Resonated, H&R Sport Springs, AFE Magnum Flow Drop In filter, Stock Flat Black Dipped Rims, Black Dipped bumper tongue, Blacked out LED Headlights, Blacked out Tail lights
Acid18 is offline   Reply With Quote
Old 01-08-2014, 06:27 PM   #12
Sarlacc
/dev/null
Sarlacc's Avatar
Drives: Uphill
This is a problem for a specific region, my GT86 does not have this "feature".
It can either be controlled by the ECU or some extra circuit added to your cars.
If controlled by the ECU it may be possible to alter the settings with Toyota Techstream software, have any of you tried that?
If it's some extra circuit it's just a matter of finding it and yanking it out.
Old 01-09-2014, 01:39 AM   #13
RevoG
RevoG's Avatar
Got the cable and software and tested on my car. Very limited with what you can actually change, but this was nowhere to be found in the techstream software.
Might be able to change it if using the full system from Toyota but they will not even entertain the idea of disabling it.
Old 01-09-2014, 11:45 AM   #14
Sarlacc
/dev/null
Sarlacc's Avatar
Drives: Uphill
Techstream is the software the dealers uses to disable seatbelt warnings etc as well as doing diagnostics, so if you didn't find it there the 120 km/h thing is probably not in the ECU but rather a "black box" circuit somewhere.
Happy hunting :-)
How to disable DRL in FRS whitefrs Cosmetic Modification (Interior/Exterior/Lighting) 12 12-13-2016 02:11 PM
Disable NAV Safety Features slizoth Electronics | Audio | NAV | Infotainment 4 01-22-2014 03:53 AM
Dealer won't disable Ecu features? DBacon1052 Scion FR-S / Toyota 86 GT86 General Forum 28 01-09-2014 08:30 AM
Dealer refusing to disable DRL's? zaptorque Scion FR-S / Toyota 86 GT86 General Forum 64 09-17-2013 04:20 PM
Is there a way to disable the immobilizer? schtebie Issues | Warranty | Recalls / TSB 5 09-22-2012 06:09 PM
