Old 04-17-2016, 12:31 AM   #1
Tomec.lunasin
Drives: 2013 Subaru brz
18x9 +30 wheel tire fitment help!
Hi guys, I recently bought 18x9 +30offset set of wheels and wondering if any of you guys have the same size can help. I'd like to know what size of tires you guys have with this set. I plan on keeping it on stock height as much as possible. Thinking of goin with 225/40 front & 235/40 rear. Would I have a problem with the tires rubbing off my fender? PLEASE HELP!
Tomec.lunasin is offline   Reply With Quote
Old 04-17-2016, 12:40 AM   #2
ryoma
ryoma's Avatar
search the forums through google and you will find your answer. use keywords like 18x9 +30 site:www.ft86club.com
the forum search function is pretty lacking.
and also browse through this thread: http://www.ft86club.com/forums/forumdisplay.php?f=24
Old 04-17-2016, 12:48 AM   #3
"Fitment"
fitment
[fit-muh nt] /ˈfɪt mənt/
Spell Syllables
noun 1. equipment; furnishing.
2. fitments, fittings : the fitments of a ship.
Fit! The word is just FIT!
Oh, and should this not have been something to consider BEFORE you bought the rims??????
TylerLieberman (04-18-2016)
Old 04-17-2016, 01:32 AM   #4
dito
Drives: SWP BRZ
u should be fine. i ran 18x9.5+34 245/40/18 and never had any rubbing issue on stock suspension
dito is offline   Reply With Quote
Old 04-18-2016, 12:11 AM   #5
Mild2Wild
Drives: Firestorm FR-S
[QUOTE=Tcoat;2624668]"Fitment"
I can't help but find the irony in your post when I see it end with that usage of "rims"...
Just busting chops, though
Mild2Wild is offline   Reply With Quote
The Following 5 Users Say Thank You to Mild2Wild For This Useful Post:
Bykov (04-18-2016), Clipdat (04-18-2016), Killerbee (04-18-2016), Tcoat (04-18-2016), TylerLieberman (04-18-2016)
Old 04-18-2016, 04:55 AM   #6
[quote=Mild2Wild;2625275]
"Fitment"
LOL Point taken!
And really I was just bustin' chops as well. I think the word "fitment" is now stuck in car vernacular as much as "rims" is.
Hey I am old enough I have to resist the temptation of referring to fancy wheels as "mags" or I would confuse most of the people here!
Old 04-18-2016, 05:57 AM   #7
Killerbee
Killerbee's Avatar
Drives: GR86 / Supra MK5 MT / MR-S / Z4
Back on Topic, the wheel choice is not really a good one if you want to Keep the Suspension stock.
Good News first, it will fit with no rubbing
Now to the bad news:
18x9 +30 will stick out in the front aobut 5-7mm on stock Suspension. You can drive like that, but depending on where you live it may be street legal or not. You can "solve this" with camber bolts (at least a bit) or with Coilovers, but it always will be not an optimal Fitting.
Tire wise, same Story. You could go for 225/40/18, however this means the tire will be streched a bit. Depending on your personal taste, you will not care or you will hate the Looks of it.
You can also go for 245/35/18, which will be a good fit for the wheel size, but this also means the tires will stick out even more in the front than the wheels. See above what this means and how you could solve it.
Killerbee is offline   Reply With Quote
The Following User Says Thank You to Killerbee For This Useful Post:
Tcoat (04-18-2016)
Old 04-18-2016, 09:56 AM   #8
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
im running 18x9 +30 in the front and i am rubbing with 3 inch drop on 225/40. If you are at stock height (or close to it) you should be okay. 225/40 will give you a mild stretch.
Old 04-18-2016, 11:11 AM   #9
Tomec.lunasin
ok thanks for the advice.. ill definitely try both of those tire size. probably get coilovers if anything
Old 04-18-2016, 11:12 AM   #10
Tomec.lunasin
i see.. hows do you like 225/40 on yours?
Old 04-18-2016, 11:50 AM   #11
NyC Zn6
NyC Zn6's Avatar
i love them for the drop that i have. Would of like to run a 235 but it would rub like crazy on the front fenders. The 225/40 still rubs but only with bumps and full lock.
Old 04-18-2016, 12:59 PM   #12
Tomec.lunasin
honestly i'd like to run with 235 as well. but i've been getting recommendation for 225/40s. for sure i'd run 235 on the rear tho
Old 04-18-2016, 01:28 PM   #13
irax
irax's Avatar
Drives: 2015 Subaru BRZ WRB
Run 235/40 all around on that 9
You shouldn't rub at all depending on your alignment.
I was running 245/45/18 on a 18x8.5 with +38 offset.
irax is offline   Reply With Quote
Old 04-18-2016, 04:37 PM   #14
Tomec.lunasin
really?cool i'll try that. thanks!
Eibach Sportline, 18x8 35, 18x9 38, 245F/265R tire/wheel fitment Q Blizzz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 08-14-2014 05:28 PM
Enkei T6S wheel and tire fitment question chenshuo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 03-30-2014 09:25 PM
need help with wheel/tire fitment bjun Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 07-04-2013 10:34 PM
Tire/Wheel fitment tool bakilman Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 08-02-2012 06:19 PM
18x9 wheel fitment and options? epson1 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 07-31-2012 05:36 PM
