Old 07-03-2013, 11:09 AM   #1
bjun
bjun's Avatar
Drives: white premium brz M/T
need help with wheel/tire fitment
I ordered a set of 18x9 +38 wheels and I've been trying to get them on but Discount Tires is telling me the wheels won't fit the front.
If I get a 245/35/18 tires all around will the wheels fit the front?
bjun is offline   Reply With Quote
Old 07-03-2013, 11:49 AM   #2
jshadeck
jshadeck's Avatar
Drives: 2013 Scion FR-S Whiteout 6MT
Yes. I have 18x9.5 +38 w a 235 but could (will) run wider than 235. What size is on it that they say wont fit?
jshadeck is offline   Reply With Quote
The Following User Says Thank You to jshadeck For This Useful Post:
bjun (07-03-2013)
Old 07-03-2013, 11:54 AM   #3
leon78
leon78's Avatar
Drives: 13 Whiteout
You will be fine since your on coilovers.
2013 Scion FR-S (Whiteout)
GunMetal 16x8+25 Enkei CompE_Cusco OCC_ Kartboy Crank Pulley_Kartboy TMM insert_Koni Yellows_RCE Springs_K&N Drop-In_Eibach FSB_J2 Catless FP_WhiteLine Camber Bolts_NameLess Track Pipe_RBF600_Ferodo DS2500_PTUNING Tuned.
Less parking more racing
leon78 is offline   Reply With Quote
The Following User Says Thank You to leon78 For This Useful Post:
bjun (07-03-2013)
Old 07-03-2013, 12:49 PM   #4
bjun
bjun's Avatar
Every Discount Tire I go to says their computer says the 18x9 +38 wheel won't fit the BRZ so they can't even do a test fit on it.
I'm trying to go 245 all around. I won't need spacers right?
The Following User Says Thank You to bjun For This Useful Post:
yoshiharadesign (07-03-2013)
Old 07-03-2013, 01:00 PM   #5
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
http://www.rimsntires.com/specs.jsp
slicktop is offline   Reply With Quote
Old 07-03-2013, 02:08 PM   #6
bjun
bjun's Avatar
http://www.rimsntires.com/wheelfit.j...u&carModel=BRZ
Even the site you posted states that the 18x9 +38 is too wide =/
Old 07-03-2013, 02:52 PM   #7
djdnz
1337
Drives: 2013 BRZ WRB S/C
They should be fine. There are numerous cars with that fitment on the forums.
Edit: sorry I thought you meant 9.5... 9" should fit fine. But here's the 9.5" examples I dug up.
Enkei RPF1 18x9.5 +38
Multiple owners of the same wheel in this thread:
http://www.ft86club.com/forums/showthread.php?t=20907
GramLight 57DR 18x9.5 +38
http://www.ft86club.com/forums/showthread.php?t=25675
djdnz is offline   Reply With Quote
The Following User Says Thank You to djdnz For This Useful Post:
bjun (07-04-2013)
Old 07-03-2013, 03:44 PM   #8
jshadeck
jshadeck's Avatar
18x9 +38 w a 245 will fit fine.
Old 07-03-2013, 04:02 PM   #9
yoshiharadesign
Their stores go with a strict guidline to prevent wrong fitments which in many cases are to help consumers from making wrong decisions. We have sent your situation over to them to review. Hopefully they can change the parameters so that in the future it is possible to install 18x9 wheels.
yoshiharadesign is offline   Reply With Quote
Old 07-03-2013, 04:51 PM   #10
yoshiharadesign
Update. They got back to me indicating that their system will update next week to allow for this variance to accept installation with this size wheel. Hope this helps out!
The Following User Says Thank You to yoshiharadesign For This Useful Post:
bjun (07-04-2013)
Old 07-04-2013, 10:09 PM   #11
bjun
bjun's Avatar
Wow that's great! Everyone on the forums is so helpful. Thanks everyone!
Old 07-04-2013, 10:34 PM   #12
nelsmar
I am on: 18x9.5 +38 (which would basically be like you running a 18x9 +32) on 245/40/18 on all four. I will be swapping to 255/40/18 in the rear, if not all 4. Just as an FYI my rear was rubbing on the bumper, it wore down within about 100 miles on the inside. Right where the plastic black push tab is.
I lowered the front 10mm more after an alignment so my camber wont be exactly what it was. But before lowering the car more i was on -2.0 Front, -2.5 Rear. I plan on pulling the front out to about -2.0 again this week when i update my alignment.
Overall it was "poking" a bit more than i wanted. I personally dont care to do heavy camber & agressive fitment but i still considering it acceptable. I wish i had around a +42 offset for mine, or a little more. Keep in mind however that all tires have a different contact patch size and fitment might be slightly different.
My front:
My rear:
My flickr - Canibeat
Local magazine scout
Wheel Directory: MM6 Mesh 18x8.5 +38 / 18x9.5 +40 ModBargains.com Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 03-14-2013 05:13 PM
Tire/Wheel fitment tool bakilman Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 08-02-2012 06:19 PM
BRZ/FR-S/86 Wheel Fitment Simulators JDMSushi Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 07-05-2012 10:49 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 01:40 AM
Wheel fitment sfwg BRZ First-Gen (2012+) — General Topics 6 10-28-2011 06:33 PM
