CANADA Canada
Old 04-16-2016, 10:58 AM   #1
oppiee
Drives: 2014 Scion FRS (Red)
How long is your winter tires lasting
Hey guys!
Finally took off my winters...only 2 seasons and I think I might have only 1 season left on them....maybe not even. Ran continental extremes...How long are your winters lasting? I wonder if its me driving it too hard. A lot of highway driving at 130 km/hr, but I feel like that shouldnt be an issue, but every time I get off the highway I can smell some burnt rubber. Doesnt happen with summers...thoughts?
cheers,
oppiee is offline   Reply With Quote
Old 04-16-2016, 02:21 PM   #2
Jegan_V
Drives: 2023 Subaru BRZ
First things first, have you eliminated all the easier items that could affect your tire wear? Things like tire pressure, alignment, etc.? Next is the driving you do, like whether you simply drive long distances if you do that unfortunately will affect the longevity. The aggressive driving can indeed contribute to increased wear particularly when the weather gets warmer since these are softer tires. Where you can unintentionally affect the longevity is where the tires are stored, if they're stored in a place with lots of light and heat...that can affect their lifespan. On the burning smell, its worth checking to see that its not brakes.
IIRC the continental winter extreme is asymmetrical so it shouldn't be an issue with wrong tire placement which is the case for directional tires.
As for my own tires, my Gislaved Nordfrost 100s are holding up very well. I suspect I can still get another 2-3 years worth out of them.
Jegan_V is offline   Reply With Quote
Old 04-16-2016, 02:30 PM   #3
D_Thissen
D_Thissen's Avatar
To add to the above, do you drive with them installed when the temperatures start hitting double digits?
Old 04-16-2016, 03:16 PM   #4
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
3 full seasons and I think I'll replace them this winter
drewbot is offline   Reply With Quote
Old 04-18-2016, 09:46 AM   #5
wparsons
wparsons's Avatar
I got 3 winters out of my first set, they probably would've lasted a 4th (especially with this past winter) but at the end of last winter I hit a chunk of metal on the 401 and mangled one of the tires. They were too worn to replace just a single tire, and instead of replacing two tires then and two tires this year I just bought a new set to keep everything the same.
flickr
Old 04-18-2016, 09:51 AM   #6
jvincent
jvincent's Avatar
Just took off my winters on the weekend and after three seasons, I put about 12K km on them each winter, three of the tires look good enough for another season.
For some reason one of them, passenger rear, had a lot more wear than the others. I didn't bother checking the pressure when I took them off but that's the probably the reason.
Old 04-20-2016, 12:17 PM   #7
oppiee
Naa I drove them pretty much only in single digits. I think I just ripp them too hard, but Its still weird that after long highway drives I smell burnt rubber at 130 km/hr. I do run them with the pressure a little higher than 36, like around 38 because it feels better maybe that's a problem too
Old 04-20-2016, 04:22 PM   #8
ProjectoGL
Drives: 2013 Scion10 FR-S
my Hankooks are champ!!! 4 seasons on my impreza and another 3 seasons on the frs when i sold the impreza....ANDDDD....it still has 50% tread left. I drive 40+ kms to and from work alone. I think the rubber is getting to hard to handle RWD so I might get new tires next season...willing to sell to AWD ppl as it will more than suffice.
2011 SWP Impreza Hatchback Sport (Sold)
::H&R springs|Nextmod Front Lip|Ichiba 25mm spacers|GP Racing bronze rims::
2013 Silver Ignition Scion 10 FR-S #1313 of 2500 (Current)
::Eibach Sportline lowering springs|Invidia Non-resonated Catless Front Pipe|Greddy EVO3 Catback|Ichiba 25mm spacers|TRD rep spoiler::
ProjectoGL is offline   Reply With Quote
Old 04-21-2016, 11:48 AM   #9
xmadror
Drives: BRZ Sport Tech 13
I got a set of used Hankook winter pike that had 1 season/±5000km.
And I've done 2 winters of also ±5000km each and they are still at 75-80%.
I expect I might have to change them before I wear them out.
xmadror is offline   Reply With Quote
Old 04-28-2016, 02:43 PM   #10
daiheadjai
daiheadjai's Avatar
Drives: 2003 S2000, 2008 Fit
My Continental Extreme WinterContacts have lasted 3 seasons (including the last winter, featuring fairly regular 250km trips between Toronto and London).
I have about 6/32 of tread left, so they're probably good for another season.
I replace them once the weather forecast shows a week or so of temps above 5 C, and rotate them to ensure even(ish) wear.
Also went down a size to 205/55R16, which probably helps as well.
daiheadjai is offline   Reply With Quote
Old 04-28-2016, 04:45 PM   #11
Maritime Storm
Maritime Storm's Avatar
Drives: 2013 Scion FR-S 6spd, Whiteout
Have 2 season on my X-Ice, expect 2 more looking at them.
Maritime Storm is offline   Reply With Quote
Old 04-29-2016, 08:38 AM   #12
aghuman
aghuman's Avatar
I also have the Conti's and I did 3 seasons including this past one. Drove about 50k on them and will replace them before next winter. I may be able to get another season out of them but for peace of mind ill probably just get a new set.
aghuman is offline   Reply With Quote
Old 04-30-2016, 04:22 PM   #13
KingGeo
Drives: FRS
I got 4 on my Toyo's, if we get another easy winter then I can likely JUST squeeze 5 out of them.
KingGeo is offline   Reply With Quote
Oem shock absorber lasting? Mars2 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 23 04-11-2017 12:21 PM
My first winter approaching, need some winter tires. Jfheisenberg Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 31 01-05-2016 08:56 PM
Tail light condensation lasting weeks sometimes months. jasonojordan Issues | Warranty | Recalls / TSB 4 05-13-2015 05:45 PM
Winter Tires worth it in Jersey for the remaining of this winter? Jfheisenberg Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 01-22-2015 10:58 AM
Hate the Tires I got with my winter tires PoRco Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 30 12-31-2012 11:49 PM
