Old 07-31-2014, 08:20 AM   #1
Mars2
Drives: GT86, AUDI RS2, VW T5 R32 Vortech
Oem shock absorber lasting?
How long do your oem shock absorber last?
My rear one after 9000 miles are leaking a lot.
Time to go for coil's
Mars2 is offline   Reply With Quote
Old 07-31-2014, 09:34 AM   #2
bfrank1972
Drives: 2013 FR-S Argento
Depends on your roads
bfrank1972 is offline   Reply With Quote
Old 07-31-2014, 07:33 PM   #3
Ubersuber
Drives: BRZ Pearl White
Should last at least 60,000 miles unless it has been damaged by a sharp impact such as a pothole. Try a warranty claim.
Good quality monotube gas pressure shocks can last the life of the car if driven normally. Even average quality shocks should last more than 9000 miles unless abused.
Ubersuber is offline   Reply With Quote
Old 07-31-2014, 08:12 PM   #4
wparsons
wparsons's Avatar
Did you (or anyone) install lowering springs, or have the upper mounts off the shocks for any reason? If the top nut was removed or re-installed with an impact gun it may have spun the inner nut loose inside the shock.
If not, definitely take it in for warranty.
flickr
Old 08-01-2014, 01:27 AM   #5
DC2R
Drives: 2014 Scion FR-S
What coils you got?
Sent from my GT-N5110 using Tapatalk
DC2R is offline   Reply With Quote
Old 08-01-2014, 02:54 AM   #6
Mars2
Oem spring and nothing did hit them. Suspension is fully oem (no mode) never been touch since day 1. 4 Oem Michelin primacy and front brake pads are also shot.
Just 9000 miles of spirited drive on smooth canyon (mountain road) and lot of drift on those thousand's of roundabout we have here in France. Here in France 20 year's ago they cancel most of the red light and made roundabout instead. Sometime going to work in the morning or back at night I go to time around each one drifting.
Old 08-01-2014, 08:06 AM   #7
bfrank1972
Wow, brakes and one damper shot, sounds like some hard miles!
Old 08-01-2014, 09:22 AM   #8
Ubersuber
Sounds like a lot of fun miles. Roundabouts make good skid pads early in the morning before the gendarmes are awake....
Old 08-01-2014, 09:23 AM   #9
jvincent
jvincent's Avatar
Methinks that the drifting might have something to do with the early failures.
Old 08-01-2014, 10:40 AM   #10
wparsons
wparsons's Avatar
Even with HARD miles, shocks should last a lot longer than 9000miles.
flickr
Old 08-01-2014, 12:21 PM   #11
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Holy crap. Definitely give warranty a shot. 9k miles is crazy. Lol
Im at 53k miles over rough roads with probably 15k being hard miles and everything is holding up fine.
Old 08-01-2014, 01:21 PM   #12
wparsons
wparsons's Avatar
I'm at 72k km's, stock shocks, no issues. I've been on Swift sport springs since easter, easily 10k km's lowered. Around 7 track days, 5+ autocrosses, two full winters, etc.
flickr
Old 08-01-2014, 05:40 PM   #13
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
No expert here, but drifting loves to kill shocks. Different angles, etc. Puts advanced wear on everything. Go aftermarket
Comparing track/autos wear to drifting wear is like comparing wear on summer to all seasons.
Old 08-01-2014, 08:47 PM   #14
wparsons
wparsons's Avatar
Drifting doesn't put any extra load on the rear shocks (which aren't struts... and aren't locating the rear knuckle) than normal driving on a track would.
The rear suspension isn't working any differently if the rear tires are or aren't spinning.
flickr
Which shock for C Street? Jawnathin Tracking / Autocross / HPDE / Drifting 17 07-05-2014 01:03 PM
shock questions cslntuee Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 04-15-2014 10:40 PM
WTB: Rear OEM Shock taimysho0 Want-To-Buy Requests 2 09-12-2013 11:23 PM
Does your FR-S shock the hell out of you when you get out? ortizwyld Scion FR-S / Toyota 86 GT86 General Forum 58 03-10-2013 11:00 AM
