Old 04-16-2016, 05:39 AM   #1
ZionsWrath
Thanks
ZionsWrath's Avatar
OEM battery not too bad?
I have completely abused this battery. It's been run flat probably more than 2 dozen times. Jump started or charged as many.
This is the original battery when I bought the car, 2012. So in a few weeks 4 years on.
Still jump starts fine and will hold enough charge to start for about a week.
Anyone else satisfied with the OEM battery? Seen a lot of negative things about it but from my experience it aint half bad.
Old 04-16-2016, 05:52 AM   #2
JD001
JD001's Avatar
Drives: Subaru BRZ
I'm afraid I'm a battery abuser too. . Don't use my car much and I can't get a trickle charger to it so the battery runs down.
I use a Snooper jump starter to get it going and it's 2 years into its life.
The Following User Says Thank You to JD001 For This Useful Post:
ZionsWrath (04-16-2016)
Old 04-16-2016, 10:26 AM   #3
We had a discussion on batteries dying in a thread a couple of months back and I spent some time digging through here. What I found was that BRZs seem to have battery issues at about a 10 to 1 ratio over FRSs. Now, since the ratio of FRs to BRZs on here is also about 10 to 1 that really is a significant trend. Presuming that both cars have the same OEM battery and the only real difference is all the electronic goodies the BRZ has I can only conclude that one or more of those goodies is creating a parasitic draw that drains batteries faster than the FRS. Hardly scientific and I can not prove my theory but there it is.
The Following 10 Users Say Thank You to Tcoat For This Useful Post:
86kahl (04-17-2016), Bristecom (10-03-2018), chaoskaze (04-16-2016), Dadhawk (04-19-2016), Hoahao (04-16-2016), JD001 (04-16-2016), roddy (04-16-2016), soulreapersteve (04-16-2016), Ultramaroon (04-16-2016), Zed (06-01-2016)
Old 04-16-2016, 10:29 AM   #4
Kimsey47
Kimsey47's Avatar
Drives: 2016 STI DGM
I was going to say that I have abused my battery too; however, I'm a BRZ driver... Car is driven once a week now after being a daily driver for the first few years of ownership that stopped in December. I guess we'll see how next winter goes but I know that I've had to jump it once and she still starts right up when I get in it now!
Subaru STI :
Old 04-16-2016, 01:45 PM   #5
Ultramaroon
not playing cards
Ultramaroon's Avatar
OEM battery is fine as long as electrolyte level is maintained. All the cells on mine cook off at about the same rate. I top it off with distilled water about twice a year.
Old 04-17-2016, 12:27 AM   #6
Somebody drinking it? year and a half and have never had to add a drop.
Old 04-17-2016, 12:53 AM   #7
aegisdrgn
aegisdrgn's Avatar
Drives: Scion FR-S 10 Series #2263
Shit, Tcoat's onto me!
aegisdrgn is offline   Reply With Quote
The Following User Says Thank You to aegisdrgn For This Useful Post:
Tcoat (04-17-2016)
Old 04-17-2016, 12:55 AM   #8
Dude! That is not what they mean when they say "do acid".
The Following 9 Users Say Thank You to Tcoat For This Useful Post:
86kahl (04-17-2016), aegisdrgn (04-17-2016), Astroboy (04-18-2016), Atropine (04-17-2016), cdrazic93 (04-17-2016), Dadhawk (04-19-2016), JD001 (04-17-2016), Pat.Thornton (04-18-2016), Zed (06-01-2016)
Old 04-17-2016, 01:06 AM   #9
aegisdrgn
aegisdrgn's Avatar
ooooo pretty...liiiiights....
Old 04-17-2016, 01:22 AM   #10
Ultramaroon
not playing cards
Hmmm... must be variations in the voltage regulator. I bet my charge voltage is higher than yours.
Old 04-17-2016, 02:30 AM   #11
aegisdrgn
aegisdrgn's Avatar
I see a ton of powder build up on the negative terminal - I cleaned it off and slathered the terminal and post with silicone paste, but it's back. I read it might be due to overcharging. Since that powder is copper sulfate, if the electrolyte level drops that means even if I add distilled water, I'll have to replace the battery sooner rather than later, right?
Pic back when I cleaned it 8 months ago:
Last edited by aegisdrgn; 04-17-2016 at 02:42 AM. Reason: bad memory - bluegreen (copper), not white (lead) powder
Old 04-17-2016, 02:56 AM   #12
Ultramaroon
not playing cards
I see a ton of powder build up on the negative terminal - I cleaned it off and slathered the terminal and post with silicone paste, but it's back. I read it might be due to overcharging. Since that powder is lead sulfate, if the electrolyte level drops that means even if I add distilled water, I'll have to replace the battery sooner rather than later, right?
The powder is due to electrolyte leeching through the compromised seal around the post. This is purely a mechanical failure. Once it starts, there's no stopping it. When you get a new battery, be sure to do everything you can to avoid tweaking the posts.
The level does not drop from that little bit leeching through the seals. It drops due to electrolysis - splitting the water molecule into atomic hydrogen and oxygen. The concentration of sulfuric acid increases as the water is lost, and decreases due to sulfation as lead sulfate builds up on the plates.
Distilled water can be added but once the plates start sulfating, that's pretty much the end of the road.
aegisdrgn (04-17-2016), cdrazic93 (04-17-2016), new2subaru (06-01-2016)
Old 04-17-2016, 08:40 AM   #13
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
Yeah my battery was dead dead after about a year and a half, switch to duralast gold. I enjoy the better cranking power of a better battery anyways. The stock battery would struggle to start the car under certain conditions
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
Old 04-17-2016, 09:58 AM   #14
babydriver
Hit the road and I'm gone
babydriver's Avatar
Still tastes better than the rot gut gin at the liquor store.
Slip, slidin' away.
The Following User Says Thank You to babydriver For This Useful Post:
Tcoat (04-17-2016)
Best two way dash cam that uses car battery and it's own battery? azynneo Electronics | Audio | NAV | Infotainment 14 01-22-2016 10:23 PM
Help! Battery died, charged battery now getting all sorts of error codes! jermyzy Issues | Warranty | Recalls / TSB 12 11-25-2015 12:35 PM
Shorai Lightweight Battery and KCMachine CNC Machined Battery Tray Package KCMachine Brakes, Suspension, Chassis 111 10-08-2014 08:26 AM
Battery tray for Braille 21lb battery? lordtakuban Engine, Exhaust, Transmission 4 09-10-2013 08:55 AM
TR-B1500 battery and billet battery tray install. mines13 DIY (Do-It-Yourself) Guides 8 12-07-2012 03:59 PM
