Old 04-15-2016, 03:18 PM   #1
Wired86
Wired86's Avatar
Drives: 2016 Subaru BRZ, Limited, MT, CBS
Engine less throaty? What?
Got my BRZ's oil changed at the dealership the other day after having finished the engine break-in. I noticed today that there seems to be a significant reduction in engine noise. And maybe a loss of power? That doesn't make any sense for an oil change to have done that does it? I tried with windows up and windows down, all with the AC and radio off. I got it all the way to almost redline and even then the engine doesn't sound as throaty as it did before. Am I just imagining this or could there be an explanation? Also it is significantly warmer today than any other day that I've had this car. Almost 70f today wheras it didn't break 45 any other day since I've had it.
Originally Posted by softgrip View Post
Last night I took a corner that would have given me a 4 wheel power slide in the WRX. The BRZ hunkered down and massacred the corner with no loss of traction or speed.
Wired86 is offline   Reply With Quote
Old 04-15-2016, 03:48 PM   #2
murdoc
Sometimes I'm wrong.
murdoc's Avatar
Drives: '13 FR-S/'96 240SX
Maybe the dealership updated or reset your ecu? It'll feel weird and sluggish as the car learns the throttle again.
Otherwise, a 30 degree temp change is enough to change how the car feels.
murdoc is offline   Reply With Quote
Old 04-15-2016, 03:49 PM   #3
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Its normal for an engine to be quieter (mechanical engine noise) after an oil change.
Old 04-15-2016, 03:52 PM   #4
GT86Moi
Drives: WRB Subaru BRZ 2016 Limited edition
How many miles did you have on your dash at oil change?
GT86Moi is offline   Reply With Quote
Old 04-15-2016, 04:06 PM   #5
Wired86
Wired86's Avatar
@GT86Moi about 1250. @murdoc yeah, maybe. They also did a full 26 point (I don't remember how many points it was, lol) inspection. Would they have reset the ECU for that? @go_a_way1 that's what I figured, the gear box seems smoother now too. So, could just be something as simple as the fact that it's quieter due to the new oil.
Old 04-15-2016, 04:08 PM   #6
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
Replaces engine oil... "gearbox feels smoother now"
That would only happen if they replaced your trans fluid..
Instagram: trevor.parque
Old 04-15-2016, 04:09 PM   #7
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Yup it will break down after 500 miles or so and be back to normal but it happens slowly so will likely not notice it.
Old 04-15-2016, 04:09 PM   #8
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Old 04-15-2016, 04:22 PM   #9
Wired86
Wired86's Avatar
Okay, maybe I'm imagining things. Haha. Yeah, I didn't think the gearbox should have changed, but it feels like it okay! Gosh.... get off my back. Haha. But really, everything does feel much more different than I'm used to post oil change. I'm still used to a 99 ford exploder that still sounded and felt like shit after an oil change. Haha.
Old 04-15-2016, 04:25 PM   #10
Wired86
Wired86's Avatar
If I want to believe in aliens, I can do that. If I want to imagine that my gearbox feels smoother to make me happier about the fact that the engine doesn't seem as loud, even though the gearbox is the same, I will do that. Haha. But really, aliens. They are everywhere. Watch your back. Keep your guns close and don't forget you only have to outrun your friends.
Old 04-15-2016, 05:03 PM   #11
navanodd
Drives: 2013 BRZ Sport-tech WRB
Its the temperature. I've never encountered a vehicle so sensitive to low engine temps before.
navanodd is offline   Reply With Quote
Old 04-15-2016, 05:38 PM   #12
My guess is they did something that required the battery to be unhooked and the ECU is just relearning.
Noticeable difference in sound and power from an oil change or temperature change?
Old 04-15-2016, 06:05 PM   #13
Wired86
Wired86's Avatar
Noticeable difference in sound and power from an oil change or temperature change?]
sounds about right to me.
Old 04-15-2016, 06:08 PM   #14
Kostamojen
Drives: 1993 Impreza w/ WRX Swap + FWD!
Did someone plug your noise tube?
Kostamojen is offline   Reply With Quote
Check Engine light on @5.7k miles and engine stalling at 4,000 rpms? djdrugga24 Issues | Warranty | Recalls / TSB 3 06-25-2014 06:06 AM
direct injector Failure , sand in the engine and on the engine aagun Issues | Warranty | Recalls / TSB 3 05-26-2014 02:46 AM
Will I get a check engine light on if the engine bay has a direct injection failure? Astroboy Engine, Exhaust, Transmission 7 03-29-2014 06:16 PM
FINALLY engine is broken in...engine/tranny smell? denverizzles Engine, Exhaust, Transmission 18 09-15-2013 08:12 PM
Engine sputtering while idling with check engine light flashing, WTF speedy racer Scion FR-S / Toyota 86 GT86 General Forum 15 08-27-2012 06:50 AM
