[||•(==(86)==)•||]
Drives: WRB Subaru BRZ Series.Blue
P0175 code after installing intake
I just installed a new intake on my car and now I keep getting the system too rich bank 2 code and a rough/low idle. How can I fix this without changing back to the stock intake?
"Guys, I'm bringing the party to you!"
-Tony Stark |
Shibby!
Drives: '14 White FR-S, '01 turbo mini taco
Tune or switch to aftermarket intake with same oem charge pipe diameter. What other mods are on?
[||•(==(86)==)•||]
Just a Works axleback. Could there be a problem with the MAF?
-Tony Stark |
#4 | |
Disconnect the battery for awhile and keep the key in the on position, see if you can reset the code and then check if it comes on again
[||•(==(86)==)•||]
It goes on one way.
-Tony Stark |
| Another CEL code | whitefrs | Forced Induction | 20 | 11-27-2019 11:27 AM |
| Perrin Cold Air Intake CEL Code? | MDS86 | Engine, Exhaust, Transmission | 9 | 02-05-2016 12:13 PM |
| Takeda aFe intake cause CEL? Code: P0171. | Figo | Engine, Exhaust, Transmission | 4 | 11-20-2014 01:45 PM |
| Installing the TRD Cold Air Intake | scottsampaio.com | Engine, Exhaust, Transmission | 23 | 11-16-2014 01:52 PM |
| P0172 Code with Injen Intake, will EcuTek tune help? | ron_jeremy | Engine, Exhaust, Transmission | 0 | 11-27-2012 11:22 AM |
