Old 02-04-2016, 06:55 PM   #1
MDS86
Drives:
Perrin Cold Air Intake CEL Code?
Can anyone post the CEL Code that pops up after driving around with the Perrin Cold Air Intake? Getting a tune done and the tuner wants the code if possible and I never got the codes scanned.
Thanks!
MDS86 is offline   Reply With Quote
Old 02-04-2016, 07:14 PM   #2
phrosty
Not sure why that'd matter to a tuner... be careful.
But, to not be completely unhelpful, if you're using the 2.75", you won't have any CELs. If you're using the 3" (BigMAF) without a tune for it, you might get a lean code due to excessively positive LTFT -- not sure about the specific code.
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
phrosty is offline   Reply With Quote
The Following User Says Thank You to phrosty For This Useful Post:
MDS86 (02-04-2016)
Old 02-04-2016, 10:53 PM   #3
MDS86
Drives:
He said it would make it easier if he knew, but it wasn't a problem. Yeah it's the 3' one. Thanks for the help though!
Old 02-04-2016, 11:33 PM   #4
steve99
If the tuner scales the maf correctly for the perrin intake then you wont trip any cel codes.
hopefully they are scaling the maf correctly and not just disabling cel codes
Likey be P0171 or P0172 to rich or to lean codes
list here
http://www.ft86club.com/forums/showthread.php?t=10691
Old 02-05-2016, 12:42 AM   #5
MDS86
Drives:
Tuner said " the system too lean too rich are disabled, the maf out of range is disabled and the maf curve is dialled in to match the new intake."
Old 02-05-2016, 01:25 AM   #6
steve99
Done a few perrin and other intakes never had to disable rich lean cel codes just scaled them up and all good
Old 02-05-2016, 01:31 AM   #7
MDS86
Drives:
Is there a problem with disabling the codes? The tuner is Dale from Castle Hill Performance if you know anything about him?
Old 02-05-2016, 02:27 AM   #8
steve99
those code are their to alert you of problems.
the rich\lean codes trip if the long term fuel trims go out of range like over 30% and the measured afr is way different than what the ecu asks for. This should not happen if everything is running correctly so i dont see why you woyld need to disavle those warnings
maybe they have some reason for doing it but i have no idea why
Old 02-05-2016, 03:53 AM   #9
JFC
Drives: 2015 86, 2015 Evo X
WTF as if Dale doesn't know the code or cant get it of the car himself.
Something not right there.
JFC is offline   Reply With Quote
Old 02-05-2016, 12:13 PM   #10
PERRIN_Chris
Drives: 2014 Subaru BRZ
Send a message via AIM to PERRIN_Chris
I agree, that's a strange question for a tuner to ask, when you're doing a tune, you shouldn't be turning off CELs, since you will want them to still be functional in case there is a real problem.
If the tuner is looking for the MAF scaling, he can download it here.
PERRIN_Chris is offline   Reply With Quote
FS: Perrin Cold Air Intake asphaltkyle Engine, Exhaust, Bolt-Ons 24 06-06-2016 09:00 PM
SOLD - Perrin Cold Air Intake w/Perrin silicone elbow killswitch Engine, Exhaust, Bolt-Ons 4 10-04-2015 01:32 AM
Perrin Cold Air Intake Professor Chaos Engine, Exhaust, Bolt-Ons 10 06-23-2015 11:42 PM
Perrin Cold Air Intake FRS_Jack Want-To-Buy Requests 0 12-16-2013 01:36 PM
Perrin cold air intake Tyson Engine, Exhaust, Transmission 5 02-15-2013 12:06 PM
