Old 04-05-2016, 08:53 PM   #1
Zeezy
Drives: Black 86 GTS
Strange noise from handbrake
So as the tile says, when on a slight decline (car shifts forward) car makes a creaking noise when the weight of the car is transfered to from the disk brakes to the handbrake.
Has anyone else experienced this?
Thanks!
Zeezy is offline   Reply With Quote
Old 04-05-2016, 09:20 PM   #2
ZionsWrath
Thanks
ZionsWrath's Avatar
When my car is in the air with handbrake on. I can turn the wheel (rear wheel) about 1.5". Maybe that is what you are hearing. I dunno, lol. I always thought that was weird on my car but the hand brake holds fine so never thought to ask about it.
Old 04-05-2016, 09:24 PM   #3
Zeezy
I don't think I've heard the noise before it just showed up today.
Old 04-05-2016, 09:32 PM   #4
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
What you are describing sounds normal. If you are using the handbrake to stop motion then you will get a clunk/creak. This is particularly evident when doing handbrake turns.
The Following 2 Users Say Thank You to Captain Snooze For This Useful Post:
Cole (04-07-2016), Ultramaroon (04-05-2016)
Old 04-05-2016, 09:33 PM   #5
KL
Drives: 2013 SWP BRZ
I've heard this noise before from handbrakes though I don't know that I've heard it from the BRZ. Just the sound of the brake pad (or in this case the shoe) being pushed against the rotor (drum for the 86s) and the wheel rotating ever so slightly before it holds.
Wouldn't worry me if I heard it from my car but I'm subbed anyway to see if someone who knows these systems better thinks it's a problem.
KL is offline   Reply With Quote
Old 04-05-2016, 09:59 PM   #6
Ultramaroon
not playing cards
Ultramaroon's Avatar
+1
Nothing wrong with it. Even when optimally adjusted, mine makes a loud clunk. Inexpensive mechanism. Gets the job done.
Cole (04-07-2016)
Old 04-05-2016, 11:33 PM   #7
Zeezy
Just to be clear the noise happens when the car is stationery and I take my foot of the foot brake, while the hand brake is up.
Old 04-06-2016, 12:04 AM   #8
Ultramaroon
not playing cards
Yes, you were clear in your OP. There's some backlash. It's normal.
Old 04-06-2016, 10:48 AM   #9
Zeezy
Thanks guys. Good to know this is probably nothing to worry about. If some shiet does happen I'll let you guys know.
Cheers!
Old 04-07-2016, 07:21 AM   #10
saj
saj's Avatar
Drives: ̶1̶0̶ ̶S̶
Yea, that is normal for most ordinary cars, don't worry your car won't roll away.
saj is offline   Reply With Quote
Strange noise Tiliziano Issues | Warranty | Recalls / TSB 1 06-05-2015 04:20 PM
New strange noise? kALMIGHTY Issues | Warranty | Recalls / TSB 45 05-02-2014 01:52 AM
Strange noise at 2500 RPM midnight23 Engine, Exhaust, Transmission 7 06-07-2013 09:01 AM
Strange Tapping noise from under car after use rhood168 Issues | Warranty | Recalls / TSB 10 02-12-2013 02:16 AM
Strange noise Random_Art Other Vehicles & General Automotive Discussions 15 06-03-2011 03:31 PM
