Old 03-28-2016, 09:58 PM   #1
lupindub
Drives: Scion FR-S
TPMS initialization question.
Just wondering if the dealer has to dismount the tire from the wheel in order to initialize a new TPMS to your car, or if they can initialize it without having to take the tire off?
lupindub is offline   Reply With Quote
Old 03-29-2016, 08:14 AM   #2
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
I believe they have to dismount them in order to get the code off the TPMS
Old 03-29-2016, 11:56 AM   #3
tobin
tobin's Avatar
Drives: '13 BRZ
I don't understand the question. Are these new wheels, new tires, and new TPMS that did not come with the vehicle? Do you already have the codes for the new TPMS?
tobin is offline   Reply With Quote
Old 03-29-2016, 08:10 PM   #4
lupindub
Drives: Scion FR-S
Nope I am getting a new set of wheel's and ideally I would have liked to go to the dealer with the TPMS mounted to my new wheel's and have them initialize it without having to remove the tire off my wheel again.
Old 03-29-2016, 11:01 PM   #5
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
You still aren't being clear in your responses. Are the TPMS SENSORS NEW? If they aren't, you shouldn't need to do anything at all.
Stang70Fastback is offline   Reply With Quote
Old 03-29-2016, 11:32 PM   #6
lupindub
Drives: Scion FR-S
Yes the TPMS is new. I am currently running without any TPMS. Sorry I had just got off a 12 + hour shift and I am tired.
Old 03-30-2016, 08:26 AM   #7
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
The way our TMPS works is the code has to be manually put into the car via tech stream. You can only have 1 set of TPM's programmed to the car. Example, if you have winter and summer wheels both with TPMS and your summers are on and thats the TPMS set you are using all will be fine until your winters go on. At that time even though they have TPMS you still need to dismount them to get the code to put into the cars computer via tech stream or your tire light will be on until your summers go back on. Then come summer tire you need to dismount your summers to get the code to program those ones to the car or the light will come on.
TLDR You can only have 1 set programmed to the car at one time. Dismount is required to get code for program. There is no way to have summer and winter wheels both with TPMS that works just by swapping wheels, a dismount and trip to dealer is required.
TPMS Question jmh128 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 03-07-2016 07:29 PM
Question about brz/frs tpms compatibility Evo2Brz BRZ First-Gen (2012+) — General Topics 15 02-16-2015 02:13 AM
Question on swapping TPMS Cards2323 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 05-12-2014 06:09 PM
TPMS question damaster32 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 01-25-2014 10:12 AM
TPMS Question Randyliciious Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 10-03-2013 02:03 AM
