Old 03-07-2016, 04:39 PM   #1
jmh128
Drives: 2016 BRZ Hyper Blue
TPMS Question
Did the search…could not find the answer.
Does anyone know if the TPMS sensor for a 2015 BRZ will work with a 2016 BRZ?
Thanks.
jmh128 is offline   Reply With Quote
Old 03-07-2016, 04:50 PM   #2
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Thanks.
They should but you will need tech-stream to program them.
Old 03-07-2016, 07:03 PM   #3
jmh128
Thanks you. I neglected to mention that the sensors are not the Subaru brand. Their something like Oro-Tek, supplied with TSW wheels. Do I still need tech-stream to program these off-brand sensors.?
Old 03-07-2016, 07:29 PM   #4
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
No idea I got OEM cuz I don't like to dˇck around hahaha! Just so you know you are going to have to reprogram them every time you swap wheels. If you are not planning on swapping wheels I would just use the OEM ones as it will be painless
ROOKIE QUESTION TPMS!! brz23 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 03-01-2015 06:05 PM
TPMS question damaster32 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 01-25-2014 10:12 AM
TPMS Question Randyliciious Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 10-03-2013 02:03 AM
Tire question about TPMS xdbuix Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 10-10-2012 08:53 PM
TPMS System Question Tanuki Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 08-28-2012 02:25 AM
