Old 03-18-2016, 10:39 PM   #1
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
I think turbo killed my factory motormounts
I'm having shuttering/shaking when I disengage the clutch from a stop. The car shifts like a dream, my clutch is act xtss never grinds my gears even at hard long shifts to redline.
More or less I can feel the car shake or shutter when I slowly eas off the gas in first or reverse.
Did my newly enjoyed turbo setup decide to eat my factory motor mounts?
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
The Following User Says Thank You to GsxrMe For This Useful Post:
raven1231 (03-21-2016)
Old 03-18-2016, 11:12 PM   #2
daironchef
Drives:
I'm not sure if it's eating your factory motor mount, but the shake you feel is the idle point your tune has set for your car, my car idle pretty calm, but sometime it does shakes when it is below 800rpm, and it goes back up.
daironchef is offline   Reply With Quote
Old 03-18-2016, 11:12 PM   #3
daironchef
Drives:
If your tune keeps doing it you might want to speak with your tuner.
Old 03-18-2016, 11:28 PM   #4
killboy
killboy's Avatar
Drives: 1FRS, 1 BRZ, 2S2000s, Evo8, Dak.R/T
How much experience do you have with upgraded/race clutches? It sounds like normal engagement from an aggressive, non-stock clutch like your ACT. As it beds in and mates up surfaces better after break-in, it will get a bit grabby. The solution is to use slightly higher revs when moving away from a dead stop. I usually target around 2500-3000 with our ACT clutch.
killboy is offline   Reply With Quote
Old 03-19-2016, 07:03 AM   #5
FirestormFlex
Drives: 2015 Turbo FR-S
It's your aftermarket clutch. I use the same clutch with my turbo setup and it chatters like crazy when starting off in first or reverse, especially after I've been driving for a while. Its enough for my wife to think there was something wrong with my car. As someone mentioned above, you'll need to get in the habit of revving a bit more at takeoff.
FirestormFlex is offline   Reply With Quote
Old 03-19-2016, 08:12 AM   #6
GsxrMe
GsxrMe's Avatar
Bingo. I guess this clutch isn't great when it warms up. I still want to replace the factory mounts but I just it's not as major.
As far as tune. The car idles perfectly and drives like a dream. Af and vac and boost is on key.
2014 Subaru BRZ
Old 03-19-2016, 04:39 PM   #7
mrk1
Drives: Sterling BRZ Ltd
Easy way to test your motor mounts. With the car off on a flat surface.
- Put car in 1st, no parking brake
- Open hood
- Lean on the front bumper to rock the car back and forth.
- You can watch the motor tilt side to side, failed mounts will move a lot and or make noise.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 03-19-2016, 06:24 PM   #8
xkalelx
xkalelx's Avatar
Drives: 2013 BRZ black
Ive got the same clutch man and exact same critique on it. It's just the soft OE motor mounts. Like you, they are not high on the list to replace with stiffer ones. The LW flywheel doesn't help NVH or low speed driveability haha
xkalelx is offline   Reply With Quote
Old 03-19-2016, 06:39 PM   #9
GsxrMe
GsxrMe's Avatar
Ok just used my go pro and it looks like the engine movement is so bad it's also hitting my 3" overpipe now.
I think I'm going to order the cusco engine and trans mounts. As I should of install it when I did my clutch and turbo install.
2014 Subaru BRZ
Old 03-19-2016, 07:12 PM   #10
ryoma
ryoma's Avatar
I have the Cusco engine mounts and I barely notice it anymore. a lot of people say that the NVH is bad with them, but it wasn't bad at all. at first, I sure felt the difference but only at idle or low speed. now, I don't even notice that I have aftermarket engine mounts. it's a good mod to do. I have all the drivetrain bushings upgraded and it makes the car feel better for sure (engine mounts, transmission mount, rear shifter mount, rear diff mount inserts & cradle, rear subframe inserts).
Old 03-21-2016, 10:56 AM   #11
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Get the Perrin mounts.
Old 03-21-2016, 11:03 AM   #12
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Do some research on the mounts before ordering. Cusco are supposed to be pretty harsh.
Old 03-21-2016, 11:06 AM   #13
nickw14
Drives: Built FA20
Does it feel like wheel hop? That's what mine does. Motor mounts are mint, I just pulled the engine yesterday lol
nickw14 is offline   Reply With Quote
Turbo from factory or aftermarket chiefshayan Forced Induction 27 03-06-2015 07:14 PM
Factory turbo FR-S - why not? reesmicm Scion FR-S / Toyota 86 GT86 General Forum 8 01-21-2014 07:45 PM
Factory Turbo BRZ ChocolateNick AUSTRALIA 34 10-31-2012 12:56 PM
factory Turbo BRZ? subatoy BRZ First-Gen (2012+) — General Topics 30 09-26-2012 03:54 PM
