Drives: 2015 FRS
Low coolant?
Hey, I noticed my car was approaching the red in the temperature gauge. I went to go check my coolant level and realized that I was COMPLETELY out of coolant... I do not track the car, and I don't really drive it too hard while daily driving. Only mods I have put on is the Perrin catback and Perrin drop-in filter.
The coolant was topped off at my last maintenance check at 7500 miles. My car currently has around 14500 miles on it. The car manual says that the coolant is supposed to last for 11 years or 137000 miles. Does anyone have any ideas as to how my car managed to go through all that coolant? I haven't noticed anything negative related to performance aside from the high temperature. My car is currently sitting in the garage. I was also wondering if there's a recommended temporary coolant to put in before I take my car in for warranty maintenance this weekend? |
buy the subaru blue coolant and just fill it up. or you can also fill up the overflow with distilled water. however, you might have air pockets in the coolant system since you have been running it empty. this is just me, but every time I gas up my car I always pop the hood and check the fluids like oil and coolant. over time, the coolant will evaporate especially if you drive in hotter climates. this is normal.
however, since you have been driving it and possibly overheated the car, taking it into the dealership is a good call. they might need to bleed the system and have them double check to make sure there are no problems.
Drives: 2016 Cosworth 2.2 BRZ
You can use Peak 50/50 long life antifreeze. It is silicate free and is safe for our engines. http://www.autozone.com/antifreeze-r...nt/513652_0_0/
Subaru recommends their cooling system conditioner. [ame="http://www.amazon.com/Subaru-SOA635071-Coolant-System-Conditioner/dp/B00IGZP2UE"]Amazon.com: Subaru SOA635071 OEM Coolant System Conditioner: Automotive[/ame] This is actually just a special kind of stop leak. They put it in from the factory and recommend it for all Subaru engines including the FR-S. Make sure that you add this back to the cooling system or that the dealer does. If this is missing, it could cause coolant to seep past the head gaskets. |
It sure does look sounds like you have a major cooling system leak ....... like a hose leaking.
Yep, I'd suggest fill it up with the OEM blue stuff (so the dealership doesn't give you grief about not using authorized coolant). Do you see any coolant under your car when parked .... ?? Let's hope the car was leaking the coolant and not burning it ...... ![]() humfrz |
Weight Weenie
Drives: 15 FR-S
Do you mean nothing in the overflow or nothing in the rad?
I do notice that my BRZ burns some coolant, though at an extremely slow rate. I usually just top it off with distilled water. last summer, I noticed that over 4 months, my coolant level dropped from the middle of high/low in the overflow to under slightly under low in the overflow when the car was cold. it also gets pretty hot in the summer (110+) and I had a few track days/canyon runs.
#7 | ||
Drives: 2015 FRS
Sorry for not clarifying, I meant nothing in the overflow, but I assumed there is very little in the radiator as well due to approaching red on the temperature gauge. Quote:
#8 | |
That's probably evaporation, there was a very large thread in the past with multiple people noticing coolant loss after the summer and such almost half empty by reading the expansion tank at operating temp if not more. They ended up finding upgraded hoses and clamps lowered the coolant loss to the atmosphere.
[insert cool phrase here]
Drives: BRZ Premium
It's 100% normal. It's called evaporation. Also poor maintenance checks. Add coolant or distilled water. Over time and the constant heat of the engine will cause that.
If you see puddles where you park your car then you have a leak. If no puddles are there your fine.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
#10 | |
humfrz |
#11 | |
Drives: BRZ Premium
As for justin6280's there could be a leak somewhere. But..... If the temp just slowly shifted on the hotter side, but not in the red. And that coolant reservoir is just empty, and no puddles on the ground. I say you just need a top off, maybe a coolant air bleed. But for now you could put distilled water and take it in, your still under warranty. Now if it just pegged to the red and steam was coming out the engine, then things could be worse.
#12 |
Drives: 2015 FRS
UPDATE: I'm so embarrassed lol. So the dealership was able to confirm the fact that there is a leak. The embarrassing part is that it is completely my fault. I installed aftermarket fog lights onto the car. I went to unbolt a bolt from the frame so that I could ground a wire. I ended up losing that bolt into the engine bay and could not find it. I assumed that it would drop out and onto the road but I was wrong. The bolt had been in the radiator in between of the fan. So the bolt has been slowly grinding against the radiator making a hole in it, creating a leak. I was quoted $987.50 to replace/repair but I decided that I will do it myself.
#13 | |
Drives: SWP BRZ
dammm one simple bolt loss gave you $987.50 to spend. time to get Koyo RAdiator. |
#14 |
| Coolant loss - Void Warranty/ Edit: coolant flush question | BRZach | Engine, Exhaust, Transmission | 15 | 01-02-2016 08:21 PM |
| Low coolant? | BRZ_STI | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 4 | 02-14-2015 05:39 PM |
| Turbo coolant lines GTX2867. Can I use the throttle body coolant lines? | mike the snake | Forced Induction | 8 | 04-01-2014 05:56 PM |
| is my coolant low? | chenshuo | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 3 | 12-19-2013 11:43 PM |
| Where did my coolant go? | ZionsWrath | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 11-02-2013 11:46 AM |
