Drives: Toyota 86
CEL Turn on after installation UEL header Tomei
Hi Guys,
Did you know whats wrong with the CEL turns on? How to fix it? is it danger for the machine? ![]() Thanks |
#2 | |
If not, a tune may very well make the CEL go away ..... plus allow the engine to take advantage of the potential extra power it could make due to the aftermarket header. humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | ShadowReaper (03-14-2016) |
Drives: Toyota 86
the CEL is most likely due to the fact that you no longer have a cat in your header. if you get a tune, it will get rid of the CEL and will better optimize your engine for the UEL header.
#5 | |
![]() humfrz |
#6 | |
the cel code will be P0420 catylist efficiency as the ecu monitor cat in header and you now have no cat. your cruise control also will not work with this code and cel active. you can reset with battery removal or by using an obd tool or scanner like torque android app on your phone and a elm327 adapter. but its going to keep comming back till you get a tune or you can try a 02 sensor spacer in the REAR 02 sensor like this http://m.ebay.com.au/itm/02-Oxygen-S...000?nav=SEARCH to try to trick ecu that their is still a cat in header, but they dont alway work 100%. as the other guys said tune is best option |
| The Following User Says Thank You to steve99 For This Useful Post: | Teseo (03-15-2016) |
Drives: 2015 86 GTS + Mitsi Lancer GSR
I had it come up for me. As Steve says, most likely P0420 which it was for me. When I checked it with my Powergate3 unit, it stated it was a permanent code, I've only had to clear it once and it hasn't come back.
If you get an OBDII scan tool (worth the money), and torque, you can clear it. But a tune is always best! |
| The Following User Says Thank You to COO86L For This Useful Post: | Teseo (03-15-2016) |
| Tomei UEL Header Installation Tips | xlid007 | Engine, Exhaust, Transmission | 65 | 02-08-2017 06:33 PM |
| Front Turn Signal Diode Dynamics Switchback Installation Question | FRS'd | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 12-27-2015 12:17 PM |
| DIY Cusco Spin Turn Knob Installation - Video Guide | Alex | DIY (Do-It-Yourself) Guides | 25 | 08-02-2015 04:03 PM |
| Ft86speedfactory UEL header vs, Tomei Expreme UEL Header | WallsAndFoundations | Engine, Exhaust, Transmission | 47 | 06-24-2015 04:50 PM |
| Switchback led turn signals installation | Scionshaun | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 05-24-2013 07:31 PM |
