Old 03-14-2016, 01:16 AM   #1
gogrfn
Drives: Toyota 86
CEL Turn on after installation UEL header Tomei
Hi Guys,
Did you know whats wrong with the CEL turns on?
How to fix it?
is it danger for the machine?
Thanks
gogrfn is offline   Reply With Quote
Old 03-14-2016, 01:32 AM   #2
Originally Posted by gogrfn View Post
Hi Guys,
How to fix it?
Thanks
Have you had your car "tuned" since the installation of the header .... ??
If not, a tune may very well make the CEL go away ..... plus allow the engine to take advantage of the potential extra power it could make due to the aftermarket header.
ShadowReaper (03-14-2016)
Old 03-14-2016, 01:40 AM   #3
gogrfn
Drives: Toyota 86
Hi Guys,
How to fix it?
Thanks
I never tuned my car yet, so it need to be tuned to make the CEL go away?
Thanks for the info btw.
Old 03-14-2016, 02:34 AM   #4
ryoma
ryoma's Avatar
the CEL is most likely due to the fact that you no longer have a cat in your header. if you get a tune, it will get rid of the CEL and will better optimize your engine for the UEL header.
The Following 2 Users Say Thank You to ryoma For This Useful Post:
CSG Mike (03-14-2016), humfrz (03-14-2016)
Old 03-14-2016, 03:44 AM   #5
Yep, see @ryoma 's post ......
Old 03-14-2016, 06:40 AM   #6
steve99
Drives: FT86
Hi Guys,
How to fix it?
Thanks
no it wont blow up :-)
the cel code will be P0420 catylist efficiency as the ecu monitor cat in header and you now have no cat.
your cruise control also will not work with this code and cel active.
you can reset with battery removal or by using an obd tool or scanner like torque android app on your phone and a elm327 adapter.
but its going to keep comming back till you get a tune or you can try a 02 sensor spacer in the REAR 02 sensor
like this
http://m.ebay.com.au/itm/02-Oxygen-S...000?nav=SEARCH
to try to trick ecu that their is still a cat in header, but they dont alway work 100%.
as the other guys said tune is best option
Teseo (03-15-2016)
Old 03-14-2016, 09:41 AM   #7
COO86L
COO86L's Avatar
Drives: 2015 86 GTS + Mitsi Lancer GSR
I had it come up for me. As Steve says, most likely P0420 which it was for me. When I checked it with my Powergate3 unit, it stated it was a permanent code, I've only had to clear it once and it hasn't come back.
If you get an OBDII scan tool (worth the money), and torque, you can clear it.
But a tune is always best!
COO86L is offline   Reply With Quote
The Following User Says Thank You to COO86L For This Useful Post:
Teseo (03-15-2016)
Tomei UEL Header Installation Tips xlid007 Engine, Exhaust, Transmission 65 02-08-2017 06:33 PM
Front Turn Signal Diode Dynamics Switchback Installation Question FRS'd Cosmetic Modification (Interior/Exterior/Lighting) 3 12-27-2015 12:17 PM
DIY Cusco Spin Turn Knob Installation - Video Guide Alex DIY (Do-It-Yourself) Guides 25 08-02-2015 04:03 PM
Ft86speedfactory UEL header vs, Tomei Expreme UEL Header WallsAndFoundations Engine, Exhaust, Transmission 47 06-24-2015 04:50 PM
Switchback led turn signals installation Scionshaun Cosmetic Modification (Interior/Exterior/Lighting) 1 05-24-2013 07:31 PM
