Old 02-26-2016, 10:46 PM   #1
els7x5
Drives: Black FR-S
Need to confirm a size not fitting stock suspension.
Quick version, will 18x9.75 +36mm fit stock suspension on a '13 FR-S?
I recently bought some XXR 550's through a shop. I told the manager the setup I wanted (staggered 17x8.5 front, 17x9.5 rear) but he recommended doing 18x9.5 +36 offset all around instead as he said he had other clients with FR-S's prefer that setup. I told him I wanted to remain on stock suspension for now and I knew that would really be pushing the limits but he claimed it would be fine so I went ahead and put in the order. However that wheel does not come in 18x9.5 it has to be 9.75. As far as I know that setup will not work for me but I wanted to be sure before calling the shop and having them change the order since it has already been shipped.
els7x5 is offline   Reply With Quote
Old 02-26-2016, 10:48 PM   #2
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
It'll poke.
jawn is offline   Reply With Quote
Old 02-26-2016, 11:02 PM   #3
els7x5
Drives: Black FR-S
But will it rub? I don't mind mild extension outside of the car but I do need it to function.
Old 02-26-2016, 11:04 PM   #4
jawn
jawn's Avatar
It'll depend a bit on your tires... but it'll be really close. You might need a 3mm spacer.
Old 02-26-2016, 11:10 PM   #5
els7x5
Drives: Black FR-S
I do like the width and will eventually go for coilovers so perhaps spacers will be just fine for now. Thanks!
Old 02-26-2016, 11:11 PM   #6
jawn
jawn's Avatar
Yeah, just don't go supermeaty with the tires. You might have to err on the side of a little bit of stretch.
Aftermarket lug nuts on stock wheels: confirm? empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 27 09-19-2018 07:38 PM
Fitting an additional O2 bung on Stock header? dave- Engine, Exhaust, Transmission 6 02-19-2015 09:54 PM
Suspension settings for different size tires Pokeguyjai Tracking / Autocross / HPDE / Drifting 2 01-24-2014 03:44 PM
Help with suspension/tire size combination... Kuzuri Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 04-14-2013 06:26 PM
fitting 17x9's with 255s, and fitting brake pads Matt Andrews Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 06-29-2012 11:08 AM
