Any headunits the same dimesions as stock?
Looking to get a double din with wider sides.
Just IMO, aftermarket double-din heatunits with adapters to make them fit in the BRZ/FRS looks out of place with the plastic on the sides. I noticed an international member here got a headunit that fits our car perfectly. Anyone know of some good models? I don't need navigation but I do want a DVD receiver and keep the stock usb ports. Last edited by Guff; 07-12-2012 at 04:24 PM. |
#2 | |
First 8600
Drives: Gen2 GR86
Apparently there is one or more Kenwood units...
http://www.ft86club.com/forums/showt...hlight=kenwood |
rookie drifter
Drives: 1987 ae86, 1985 celica gts
Search ebay for 200mm wide double DIN and all you will find will be some cheap stuff but I think I will try one and let everyone know about it
look at this http://www.dhgate.com/7-quot-hd-scre...22d507ded.html Last edited by alexmotrix; 06-30-2012 at 01:24 AM. |
#5 | |
I'm not planning on replacing mine right now, so I'm hoping by the time I do someone comes up with a replacement dash trim that has a standard DIN cutout in it. |
Drives: Brz, Legacy
So I can't just plug in any double din?
Trackday ride with built motor
Mods: Going, Stopping, Handling Parts: CP, Pauter, Sprintex, Ecutek, Milltek, STI, Rays, Defi, Essex AP Racing, Bilstein, Whiteline, Perrin, RacerX |
You can but you'll need a kit to cover the gaps on the side that you'll have.
This is for the frs, not sure if the brz is using the same wide head unit size
Encity's Firestorm MT Car Journal:
http://www.ft86club.com/forums/showthread.php?p=252545 |
Drives: Brz, Legacy
It has got to be the same; I'll take a look
Many thanks
#9 | |
Drives: Brz, Legacy
I presume the frs/brz hole is taller than the 100mm standard double din height too. Does anyone have the exact measurements of the stock unit?
#10 |
Drives: None
Not sure what your reason for the unit "having to be the same is" but you can easily achieve the flush/stock look by simply buying a kit that will fill the holes created by the sizing difference between the stock unit and the standard DIN size headunit sold by most manufacturers.
#11 | |
Drives: '14 Monogram FR-S(RIP)
#12 | |
#13 |
Thanks for the replies guys. I'm still looking for a good headunit
![]() I agree. If there was a way to get a "filler" that had the same exact texture and pattern as the surrounding dash, that would be my first choice since the standard double-dins are widely available |
#14 |
VMFIC ORLANDO SCIKOTICS
My FR-S came with the Bespoke Head Unit. The Bespoke I-Phone app is currently crap but the headunit isn't that bad. I find the response with Pandora is very responsive and it scrolls my I-pod very quickly. The touchscreen works great with the phone functions as well. I will be changing it out at some point but I'm not in that big of a hurry.
"Silence is acceptance so start talking or quit bitching!"
| USB on the stock radio | Dadhawk | Electronics | Audio | NAV | Infotainment | 70 | 02-25-2013 05:48 PM |
| BRZ stock in BC | delsol97 | CANADA | 8 | 07-05-2012 09:39 PM |
| [SYD] Swap my stock GTS 17" for your stock GT 16" wheels | eckoflyte | AUSTRALIA | 11 | 06-18-2012 08:17 AM |
| BRZ stock nav - does it have RCA out? | wootloops | Electronics | Audio | NAV | Infotainment | 1 | 06-17-2012 02:01 AM |
| Stock or JZ? | Samdajiggaman | Engine, Exhaust, Transmission | 62 | 05-25-2011 06:12 PM |
