Old 06-29-2012, 02:44 PM   #1
Hanakuso
Any headunits the same dimesions as stock?
Looking to get a double din with wider sides.
Just IMO, aftermarket double-din heatunits with adapters to make them fit in the BRZ/FRS looks out of place with the plastic on the sides. I noticed an international member here got a headunit that fits our car perfectly. Anyone know of some good models? I don't need navigation but I do want a DVD receiver and keep the stock usb ports.
Hanakuso is offline   Reply With Quote
Old 06-29-2012, 03:16 PM   #2
I had a chat with a "technical advisor" at Crutchfield and his response was no, they don't carry anything that doesn't require a fitment kit in a Toyota. He was less than convincing though since he consistently used "most" and "nearly all". Never could get him to say "all" or "none". I hadn't had time to go back and look for the model # you mention above but if you find, it might be worth having a chat with the number and see if there is an equivalent.
Old 06-29-2012, 09:54 PM   #3
K2
First 8600
K2's Avatar
Drives: Gen2 GR86
Apparently there is one or more Kenwood units...
http://www.ft86club.com/forums/showt...hlight=kenwood
K2 is offline   Reply With Quote
Old 06-29-2012, 10:42 PM   #4
alexmotrix
rookie drifter
Drives: 1987 ae86, 1985 celica gts
Search ebay for 200mm wide double DIN and all you will find will be some cheap stuff but I think I will try one and let everyone know about it
look at this http://www.dhgate.com/7-quot-hd-scre...22d507ded.html
alexmotrix is offline   Reply With Quote
Old 06-30-2012, 10:02 AM   #5
Right, but those aren't sold in the US and AM/FM differs between companies so you can't always import them.
I'm not planning on replacing mine right now, so I'm hoping by the time I do someone comes up with a replacement dash trim that has a standard DIN cutout in it.
Old 07-01-2012, 04:46 PM   #6
ICantAffordAnLFA
ICantAffordAnLFA's Avatar
Drives: Brz, Legacy
So I can't just plug in any double din?
Trackday ride with built motor
Mods: Going, Stopping, Handling
Parts: CP, Pauter, Sprintex, Ecutek, Milltek, STI, Rays, Defi, Essex AP Racing, Bilstein, Whiteline, Perrin, RacerX
ICantAffordAnLFA is offline   Reply With Quote
Old 07-01-2012, 04:56 PM   #7
encity5
encity5's Avatar
You can but you'll need a kit to cover the gaps on the side that you'll have.
This is for the frs, not sure if the brz is using the same wide head unit size
encity5 is offline   Reply With Quote
Old 07-01-2012, 05:03 PM   #8
ICantAffordAnLFA
Drives: Brz, Legacy
It has got to be the same; I'll take a look
Many thanks
Old 07-08-2012, 04:18 AM   #9
ICantAffordAnLFA
Drives: Brz, Legacy
Ok, so the frs/brz hole is designed to fit a 200mm wide unit, vs 180mm wide for standard double din.
I presume the frs/brz hole is taller than the 100mm standard double din height too.
Does anyone have the exact measurements of the stock unit?
Old 07-12-2012, 01:45 AM   #10
onedollarodent
Drives: None
Many thanks
Not sure what your reason for the unit "having to be the same is" but you can easily achieve the flush/stock look by simply buying a kit that will fill the holes created by the sizing difference between the stock unit and the standard DIN size headunit sold by most manufacturers.
onedollarodent is offline   Reply With Quote
Old 07-12-2012, 01:49 AM   #11
Trojan_SC
Trojan_SC's Avatar
Drives: '14 Monogram FR-S(RIP)
I think the OP's point is to avoid those kits. They look tacky. It would be nice to have a head unit actually be flush instead of having a "flush look".
Trojan_SC is offline   Reply With Quote
Old 07-12-2012, 08:53 AM   #12
Exactly. If the filler matched the dash pattern it might be OK, but since it doesn't its an obvious filler and you can tell. I'd notice it every time I got in the car.
Old 07-12-2012, 01:01 PM   #13
Hanakuso
Thanks for the replies guys. I'm still looking for a good headunit
I agree. If there was a way to get a "filler" that had the same exact texture and pattern as the surrounding dash, that would be my first choice since the standard double-dins are widely available
Old 07-12-2012, 04:10 PM   #14
greenguy101
VMFIC ORLANDO SCIKOTICS
greenguy101's Avatar
My FR-S came with the Bespoke Head Unit. The Bespoke I-Phone app is currently crap but the headunit isn't that bad. I find the response with Pandora is very responsive and it scrolls my I-pod very quickly. The touchscreen works great with the phone functions as well. I will be changing it out at some point but I'm not in that big of a hurry.
"Silence is acceptance so start talking or quit bitching!"
greenguy101 is offline   Reply With Quote
USB on the stock radio Dadhawk Electronics | Audio | NAV | Infotainment 70 02-25-2013 05:48 PM
BRZ stock in BC delsol97 CANADA 8 07-05-2012 09:39 PM
[SYD] Swap my stock GTS 17" for your stock GT 16" wheels eckoflyte AUSTRALIA 11 06-18-2012 08:17 AM
BRZ stock nav - does it have RCA out? wootloops Electronics | Audio | NAV | Infotainment 1 06-17-2012 02:01 AM
Stock or JZ? Samdajiggaman Engine, Exhaust, Transmission 62 05-25-2011 06:12 PM
