Old 02-21-2016, 11:21 PM   #1
ort895
ort895's Avatar
True dual exhuast
I tried searching but nothing came up. Has anybody ever looked into this? I feel like it would be pretty interesting. Taking some welding classes right now, may look into it myself lol
Yeah its an auto, deal with it.
ort895 is offline   Reply With Quote
Old 02-21-2016, 11:29 PM   #2
swarb
Why?
Why stop at two? why not make it a true quad?, one for each cylinder.
You are going to have a hard time making a over pipe and have lots of clearance issues. And then finding the right shaped(oval? half circle?) piping to make it happen. And then it is going to be heavy. Don't waste your time.
Old 02-21-2016, 11:40 PM   #3
ort895
ort895's Avatar
Originally Posted by swarb View Post
Why?
I thought it would be a pretty cool project, especially if done right. But thanks for the opinion!
Old 02-21-2016, 11:56 PM   #4
ryoma
ryoma's Avatar
if you have the time and material to do it, definitely do it if you want to. though, you will most likely run into problems since the stock overpipe is already so tight I doubt you will be able to run another pipe through the same spot. I don't even think there is room on the driver side either unless you go under the subframe.
but then think to yourself if it's worth it in the end lol
Old 02-22-2016, 01:15 AM   #5
churchx
churchx's Avatar
Drives: 2014 GT86
1) if there are two pipes, individual diameter of each should be lesser, hence ease routing of two?
2) imho it's not THAT hard, after all, Ace header's overpipe somewhat already does that
3) i'd still drop that idea due weight dual pipe design will bring, and extra costs (especially due one-off custom work and due need to design all the exhaust till end of car this way) / complexity. Or do that only with direct side exhausts, where issues of weight and need to make rest of exhaust dual too would be lesser.
Old 02-22-2016, 03:46 AM   #6
humfrz
Well, now, ort895, if you can pull that off ....... I'd say you would deserve an "A+" in your welding class .......
humfrz
Old 02-22-2016, 07:10 AM   #7
ort895
ort895's Avatar
humfrz
lol not just me, got a couple of good people looking for a project.
The Following User Says Thank You to ort895 For This Useful Post:
humfrz (02-22-2016)
Old 02-22-2016, 07:59 AM   #8
jarnojvv
jarnojvv's Avatar
Drives: 86|Fortuner|FJ|Mustang|SwiftSport
So, as a DIY project this would be pretty cool IMO. Functionally probably not as good, but i would love to see the end result!
-JvV-
jarnojvv is offline   Reply With Quote
The Following User Says Thank You to jarnojvv For This Useful Post:
ort895 (02-22-2016)
Old 02-22-2016, 08:58 AM   #9
churchx
churchx's Avatar
Drives: 2014 GT86
BTW, imho much easier to route two pipes where overpipe portion is if pipes are not round there, for example D shaped, no?
The Following User Says Thank You to churchx For This Useful Post:
ort895 (02-22-2016)
Old 02-22-2016, 10:16 AM   #10
ort895
ort895's Avatar
That's what i assumed. I wish i retained more from my 3D modeling classes in high school lol
Old 02-22-2016, 10:17 AM   #11
ort895
ort895's Avatar
if i do indeed do it its not going to be for "gains" since you dond't really see anything noticeable on n/a cars anyway. Im in it mostly for the sound it could produce and the uniqueness.
Old 02-22-2016, 10:33 PM   #12
Ashikabi
Ashikabi's Avatar
Run them out the vents in the front fender. Kthxbai
Old 02-22-2016, 10:55 PM   #13
[YOYO]
Amazing Member
[YOYO]'s Avatar
Drives: 2014 Whiteout FR-S
To quote Brick Tamland, that'll be good for lots of . . .
MY 86 BUILD
[YOYO] is offline   Reply With Quote
The Following User Says Thank You to [YOYO] For This Useful Post:
Chrisgalactic (02-24-2016)
DC Sports Dual Canister Exhuast Robert95g Engine, Exhaust, Transmission 13 03-29-2016 12:28 AM
Exhuast Shops UchihaFanBoy NY / NJ / CT / PA 3 02-14-2015 01:28 PM
FS: TRD exhuast Obja Engine, Exhaust, Bolt-Ons 4 07-14-2014 11:14 AM
WTB Trd exhuast $500 davebrus Want-To-Buy Requests 1 03-19-2014 09:36 PM
True Dual Exhaust? jm1681 Engine, Exhaust, Transmission 17 10-07-2012 11:47 PM
