Old 10-05-2012, 01:14 PM   #1
jm1681
Drives: MKVI VW GTI
True Dual Exhaust?
Just when you thought I couldn't ask another strange exhaust question, how's this?
Seriously though, why not?
Yeah, law of diminishing returns, I get that, but theoretically, couldn't you split the exhaust at the header, put a cat in each and be pretty good to go?
Plumbing could be kept to a relatively small size since each pipe wouldn't need to flow as much as a single, and if flow dynamics are proportionate, shouldn't the cats be pretty happy to boot?
What would the point be? Possibly better sound? Possibly more power since there is less gas passing through each cat? I don't know really, it was just something I was thinking about.
jm1681 is offline   Reply With Quote
Old 10-05-2012, 01:41 PM   #2
fmsida
Drives: 2013 DGM BRZ
You will probably need two pipes at about 1.5" - 1.75" diameter running alonside in the space provided in the tunnel. Could seem a little diffucult to place to smaller cats, two pipes, (resonated or not), you will need at X or H-pipe to get better performance and decrease drone, after that you will need mufflers.
If you have time, money, and skils, you may be able to pull it off. Not mention you will probably need a tune as well, seing that the primary cat has an Oxygen sensor. (you could remove, but you the risk of getting a C.E.L.). The biggest obstacle would be running exhaust manifold runners up and over to where about the resonator starts.
hope that gives you an idea.
fmsida is offline   Reply With Quote
Old 10-05-2012, 02:38 PM   #3
jm1681
Drives: MKVI VW GTI
I figured it would be a hell of an endeavor, but in the pursuit of cool exhaust noise, endeavors be damned XD
Now I just need a huge bankroll to try it >.<
Old 10-05-2012, 02:49 PM   #4
G-Man
G-Man's Avatar
Drives: 1980 corvette, 2014 Subaru BRZ
besides the not seeing much gain, I think it will be very hard to pull off. here is how much room the car has for exhaust
G-Man is offline   Reply With Quote
Old 10-05-2012, 03:12 PM   #5
eclipsed
Drives: Firestorm Fr-S
In my experience, very little if anything is to be gained from going true dual exhaust on a 4 cylinder engine and often impacts mid range power negatively. Save that stuff for the v-8's.
eclipsed is offline   Reply With Quote
Old 10-05-2012, 04:18 PM   #6
fmsida
If you want to try something different, you could get a small X-pipe. Split into two smaller pipes after the resonator, followed by the small X-pipe, then finsh it off with two small mufflers towards the exit. I would suggest replacing the mid pipe with a 2.5" pipe to increase the flow and sound.
I can almost gurantee that you wont get any gains, however the possibility of different sounds and pops may present itself. I was contemplating on doing this knowing I wouldn't get any gains, but having a different sound may have been worth it.
Old 10-05-2012, 04:27 PM   #7
Foobar
SLO NO MO
Foobar's Avatar
I also don't forsee any tangible gains to offset the additional weight of a true dual system. Might have an interesting sound for the Boxer engine though.
Not much room underneath our cars to accommodate it either, I don't think.
Old 10-05-2012, 04:48 PM   #8
jm1681
Drives: MKVI VW GTI
My thoughts exactly
Old 10-05-2012, 07:46 PM   #9
Captain Insano
I was thinking bout this the other day. I think you could do it a lot easier from a fitmrnt perspective without cats. Would be super interested to hear how that would sound!!
Old 10-05-2012, 09:29 PM   #10
seven
Tells it like it is
seven's Avatar
Drives: SS1LE | F150 Diesel | Civic | S3
To be short and blunt...
-It's a 2.0L
-It's a 4 cyl - yes flat 4 but still a 4
-It's NOT a large V6 or V8
-The scavenging effect of an X-pipe thats 1.5 x 1.5 is kinda useless.
-You'd need more mufflers, cats, resonators, etc (everything but tips really), AND an x-pipe - so the cost goes up, quite a bit
Basically... it costs too much, does too little, and has no real necessity. You can do it to say you did it... and then anyone with half-sense will call you foolish.
seven is offline   Reply With Quote
Old 10-05-2012, 09:35 PM   #11
WolfsFang
Scrape Master
WolfsFang's Avatar
Drives: Goal: Oldest FRS State Side
I was thinking about this when I first got my car.
You do realize comparing the BRZ to the FR-S is like comparing which hand you love masterbating too right?
WolfsFang is offline   Reply With Quote
Old 10-05-2012, 09:39 PM   #12
pdreams
Sounds similar to what Greddy Japan released for their catback exhaust.
GTS V2 exhaust.
pdreams is offline   Reply With Quote
Old 10-05-2012, 09:49 PM   #13
Captain Insano
-It's a 2.0L
I was thinking just piping with maybe only one resonator per pipe to keep it fairly light when I was thinking about this possibility. Not arguing, just saying what I was thinking at the time. :-)
Old 10-06-2012, 05:22 PM   #14
jm1681
Drives: MKVI VW GTI
You'd need more mufflers, cats, resonators, etc (everything but tips really), AND an x-pipe - so the cost goes up, quite a bit.
I actually don't think you need a lot of that.
The car comes with two cats, so those are free, and with the size of the plumbing in question (1.5"-1.75"), I REALLY doubt you'd need extra resonators, if any at all. Probably a single muffler for each half, and you're good.
PTUNING FR-S/BRZ DS-325 3" Dual Cat Back Exhaust System ... Coming Soon!! Mrc@ptuning Engine, Exhaust, Bolt-Ons 246 04-06-2014 12:52 PM
Agency Power SS Dual Exhaust | Lowest Price on FT86Club @ ECS Motorsports + FREE S&H! AJ@ECSMotorsports Engine, Exhaust, Bolt-Ons 26 04-10-2013 10:15 AM
Dual exit muffler delete Hardrock4445 Engine, Exhaust, Transmission 22 02-13-2013 08:41 PM
Exhaust system: dual or single KiingDavid Engine, Exhaust, Transmission 162 05-04-2012 01:33 AM
Red Toyota 86 TRD (dual exhaust) just86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 0 04-04-2012 08:48 PM
