Old 02-15-2016, 01:45 PM   #1
Nonexistent
Nonexistent's Avatar
Drives: 2016 FR-S
Aftermarket head unit with stock backup camera and mic?
I just bought a new 2016 FRS and was thinking about getting the Pioneer AVHX5700BHS. Is there a way to hook up the stock backup camera and mic to this head unit? Maybe a harness or something? Thank you all in advance.
Nonexistent is offline   Reply With Quote
Old 02-21-2016, 03:31 PM   #2
Nonexistent
Drives: 2016 FR-S
I found this.
Axxess AXTOYCAM2 for Toyota Toyota Back-Up Camera Retain/Add-On Harness.
http://www.autotoys.com/x/product.php?productid=32189
Do you think this will work to keep stock backup cam with aftermarket head unit?
Old 02-26-2016, 01:41 AM   #3
treminaor
"DGM BRZ"
treminaor's Avatar
Drives: 2016 BRZ Limited
I've run into the same question while installing a AVHX8500BHS into my 2016 Subaru BRZ... have you tried that harness? What were your results?
I'm also having trouble getting the front door speakers to work with the aftermarket HU. I've read that the "System Remote Wire (Blue/White)" on the Pioneer harness needs to go to Pin 8 (Blue) of the Toyota harness but that's not working, the amp isn't being powered.
Edit: I found out why the speakers don't work. Toyota moved the AMP trigger wire to the new 28 pin harness. You have to wire your System Remote Wire (Blue/White) to the brown wire in Pin 9 of the 28 pin harness. See here for more info: http://www.ft86club.com/forums/showp...1&postcount=22
I think that harness you linked has all 28 terminals pinned out to wires... so theoretically you could buy it to use for the backup camera wiring and also solve the amp trigger issue with it. I guess I'll go ahead and order it from http://www.sonicelectronix.com/item_...X-TOYCAM2.html
Edit 2: Don't waste your money on that harness, it's the wrong one. Doesn't even match the pinout of the 2016 BRZ harness much less fit onto it. I'm going to see if there's anything I can do with it to make it work before sending it back.
treminaor is offline   Reply With Quote
Old 06-26-2017, 09:20 PM   #4
kothetimeless
Drives: 2017 Subaru BRZ
Any update guys? I am using this as a guide but there's gaps because they didn't use a Pioneer. I think the backup Cam is good to go via this thread but I need help with OEM microphone and steering wheel controls SWC.
kothetimeless is offline   Reply With Quote
Old 06-26-2017, 09:21 PM   #5
kothetimeless
Sorry here is the thread I am referencing: http://www.ft86club.com/forums/showthread.php?t=111866
Reverse Camera on stock 2015 head unit iLaw Electronics | Audio | NAV | Infotainment 18 04-29-2017 12:35 AM
Backup camera for AXCP-Q14U T10015 pioneer touchscreen head unit infamous_s Electronics | Audio | NAV | Infotainment 8 02-21-2017 11:44 AM
Can I buy rear camera and head unit 2016 Mikeez Electronics | Audio | NAV | Infotainment 25 03-02-2016 10:23 AM
OEM Reverse Camera and aftermarket head unit map26 Electronics | Audio | NAV | Infotainment 0 07-27-2015 09:47 AM
BRZ Stock Head Unit + Aftermarket Amp + 3-way Components question daforce007 Electronics | Audio | NAV | Infotainment 13 04-14-2013 04:42 PM
