Old 03-01-2015, 02:07 PM   #1
iLaw
iLaw's Avatar
Drives: 2015 BRZ, Aozora Edition
Reverse Camera on stock 2015 head unit
Hey all,
I have a 2015 BRZ with the OEM Subaru/Fujitsu head unit.
I have a few questions:
1) I was wondering if anyone has installed a reverse cam?
2) How well does it work with the head unit?
3) What camera did you buy?
4) What How To/DIY guide did you follow (if any)?
Thanks in advance!
iLaw
2020 Subaru Crosstrek Sport
2015 Subaru BRZ Aozora Edition (Sold)
iLaw is offline   Reply With Quote
Old 03-01-2015, 02:25 PM   #2
menikmati
Drives: 2015 BRZ, 2005 STI, 2024 Type R
Originally Posted by iLaw View Post
Hey all,
Yes.
I mounted mine in the OEM location on the trunk fascia, so my parking lines are at an angle and not dead center on the head unit screen. I use the camera more for gauging distance, not to see if I'm parking straight.
Rydeen Duo, was ~$75 new on eBay.
I used this as a general guide:
http://www.ft86club.com/forums/showthread.php?t=17020
I purchased this harness and it was 100% plug and play:
http://www.autoharnesshouse.com/19867.html
Thanks in advance!
Most difficult part was routing the wires from the headunit to the trunk.
menikmati is offline   Reply With Quote
Old 03-01-2015, 11:57 PM   #3
iLaw
iLaw's Avatar
Thank you for your reply. It helped me greatly.
Did the harness help a lot? Was it easy to install?
Did you have to purchase the "Reverse Trigger Wire" that was mentioned in the AutoHarnessHouse link?
Thank you.
iLaw
Old 03-02-2015, 12:21 AM   #4
menikmati
Thank you.
The harness allowed for a 100% plug and play install. Could I have pieced together a homemade harness with the correct wiring and relay? Yes, but I felt that the pre-made harness was well worth it. The harness allowed for easy integration of the backup camera to the head unit with minimal headaches and complications.
I was originally going to purchase the harness from http://ae64.com/Products.htm but I found that the link I posted earlier was cheaper and had everything I needed. I did not have to purchase the Reverse Trigger Wire and everything functions properly.
Old 03-02-2015, 07:39 AM   #5
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
I was planning to go with the harness + camera from Beatsonic:
http://www.ft86club.com/forums/showthread.php?t=41673
Seems the most straight forward and I know it'll work since so many have tried it.
PandaSPUR is offline   Reply With Quote
Old 03-03-2015, 04:05 PM   #6
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
really wanna do this.....but I need a beer & buddy to do it
Old 03-03-2015, 09:07 PM   #7
menikmati
This can be applied to more than just backup camera installation.
Old 03-07-2015, 07:39 PM   #8
Monoman
Drives: '13 BRZ - SWP
My notes from when I put a backup cam in my 2013. Maybe the info can help.
Monoman is offline   Reply With Quote
Old 03-07-2015, 08:13 PM   #9
tracerit
Drives: '13 SSM BRZ Limited 6MT
Great resource, those are all the links I've bookmarked for my install as well. If I can add, this is the cable that you want: http://www.ft86club.com/forums/showp...3&postcount=78
ae64.com has three different cables listed and being an audio noob I wasn't sure which one to get, but was advised on that one.
tracerit is offline   Reply With Quote
Old 02-13-2016, 04:38 PM   #10
gcranston
Drives: 2015 Subaru BRZ Limited DGM
That large black box on the harness (relay?), did you secure it somewhere?
gcranston is offline   Reply With Quote
Old 02-13-2016, 05:31 PM   #11
ryoma
ryoma's Avatar
I just let it hang around in the bundle of wires lol. it's pretty tight in there so I doubt it will be moving a lot.
Old 04-28-2017, 02:02 PM   #12
BaBaFlyingSheep
Drives: 2015 BRZ Ltd 6MT
I am super HU noob. Where does the parking brake connector (DRL connector) go with the autoharness version? Did you splice into the harness?
BaBaFlyingSheep is offline   Reply With Quote
Old 04-28-2017, 02:34 PM   #13
NickB34
Drives: 2014 BRZ
The parking brake signal already goes to the head unit, you unplug that connector and plug it into this one if I'm remembering my install correctly. I recommend the harness as well since it was super simple to connect. The only thing you do with the harness is plug in your video cable from the camera and connect the 12V power to the camera. Make sure you get a camera that can tolerate the 12V.
NickB34 is offline   Reply With Quote
Old 04-28-2017, 04:04 PM   #14
BaBaFlyingSheep
There's no 16-pin to connect it back into, check it out.
Two 10-pins, so whatever you take out, you connect it back into the harness.
But there's only one 16-pin connector.
Speaking of the 10-pin, I'm having a nightmare with this, it's not keyed correctly to the back of the head unit.
Why is this so difficult? Should've been easy, plug, and play.
Backup camera for AXCP-Q14U T10015 pioneer touchscreen head unit infamous_s Electronics | Audio | NAV | Infotainment 8 02-21-2017 11:44 AM
2015 scion head unit speedracer45 Audio/Visual, Electronics, Infotainment, NAV 13 03-31-2015 08:27 AM
FS: OEM frs 2015 head unit mynameis940 Audio/Visual, Electronics, Infotainment, NAV 17 12-04-2014 12:39 PM
2015 BRZ Head Unit Makattack BRZ First-Gen (2012+) — General Topics 18 09-21-2014 02:53 AM
anyone interested in a bespoke unit w reverse camera? xpicer NY / NJ / CT / PA 3 11-03-2012 06:57 AM
